Solved BIOS beep, PC posts, but red LED light on GPU and no monitor signal
There is very little possibility that the card would fail while out of the PC. The only possibilities are static electric short, or impact damage (dropping it).
What you did while testing was fine, and it should prove that the card is working - leaving us back with that new cooler.
Your idea to try the old heatsink with a new fan is a good one. That will tell if the card is good and may shed some light on what in the installation of the new cooler is wrong, if anything.
You want to try and make every connection and contact with the new cooler exactly the same as the old one. And when you pull the cooler off, check to see if the thermal compound spread. If the cooler is not making good contact with the GPU because of some obstruction that would explain it too.
Home Built - Jan 2013
i7-3820
Asus P9X79-PRO - Bios 4608
GSkill F3-14900CL9Q - 16GB
On board Realtek ALC898
Acer S271HL
#1- Samsung 840 Pro Series
Corsair Obsidian 550D
MS KC-0405
Intellimouse 5-button
56 Mbits/Sec (on a good day)
Avast & Malwarebytes
Asus DVD - DRW-24B1ST 24X
I just removed the Accelero cooler and some light really has been shed. The cooler wasn't touching the GPU at all. There is next to no thermal paste on it whatsoever. I've tried thinking of every possible way to make the cooler touch the card better, but nothing works. It's just too big for the card. What a huge disappointment. At least I can save the cooler for a future card and hope it comes in handy one day.
I still have yet to connect the old cooler, so I'll return after I've applied it and put it back on the mobo.
EDIT: The wires are too big to fit in the small connector that went with the first fan that came with the original cooler. Could I put the wires directly into the pins?
Windows 7 64-Bit Home Premium Service Pack 1AMD Phenom II Black x4G. Skill Ripjaws Gaming series DDR3 2 x2GBSapphire ATI Radeon HD 5770 PCIe
Asus M4A89TD Pro USB3
Western Digital Caviar Blue 500gb SATA 6.0
Corsair HX 650w
Cooler Master CM690 II Advanced
Sure you can.
1.Don't bend any pins
2. Make sure they don't touch each other
3. Make sure the wires are on the proper pins
4. Make sure that the harness is secure so the wires don't come off.
If at all possible use the connector because it does those 4 things.
The wires are thick enough where I don't think they'll slip out, but they do knock into each other a lot. Would it work to slip something like a piece of foil or paper in between them to hold them? Here's a picture of how it looks right now.
Corsair HX 650w
Actually a piece of electrical tape could be wrapped around that outer shell. That would work best to electrically separate the two leads.
Glad to hear you found the problem. Sorry to hear the cooler is incompatible with the card.
Can you see or determine what is obstructing it from making full contact? Is it the capacitors?
i7-3820
Acer S271HL
MS KC-0405
Just wrap the tape around the white plastic area you mean? Or the metal tips on the end?
And I'm not sure what exactly was blocking the cooler. From looking it all over I couldn't even tell what would have done it. I'm guessing that it was one of the memory coolers all around it, and I suppose I could use just the cooler and now the memory heatsinks, but I figured I'd try this first.
Corsair HX 650w
Don't put foil between the leads! That will short it our. Slip a piece of electrical tape between the leads and wrap it around, either one would work.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
Please no foil of any kind. They are conductors of electricity. If you can find it I would use the proper size of heat shrink tube. Using electrical tape might not give you enough room because of the thickness to install the wires without bending the pins. Try the tape but be careful. Broken pins means new card.
This thread was/is like an epic tale. Nice plot development with a twist of an ending; kept me on the edge of my swivel chair.
Looks like some other people have complained about that cooler, one I noticed had the card you have, too. Sickly products marketed as a panacea, and so it goes...
Windows 7 Home Premium x64AMD FX-8150Corsair Vengeance Dual-Channel 1866MHz 8GB (2...x2 Galaxy GeForce GTX 560 2GB in SLI
Mine
AMD FX-8150
ASUS Sabertooth 990FX
Corsair Vengeance Dual-Channel 1866MHz 8GB (2x4GB)
(Onboard) Realtek ALC892
Dynex 42 inch HDTV
Seagate Barracuda 2TB (SATA);
My Book 300GB (USB);
My Book 3TB (USB)
Kingwin KX-1000
Corsair Carbide 500R
Corsair H100
Logitech Wireless Solar K750
Logitech Wireless M305
DSL (unsure of details)
LiteOn iHBS212 Blu-Ray Writer (SATA)
Well there's a happy ending to the tale. I fixed my card and it is now in proper working order with the new fan on the old heatsink. I didn't have to buy a whole new card, although I'm out 35 bucks ordering that damn Accelero. I guess I'll keep it in my PC parts box for future use (kindling a bonfire maybe).
But the new fan on the old heatsink is spinning and working just fine, and quiet, too. I'm using good ol' Arctic Silver compound on the heatsink now.
Thanks for helping me guys, and giving me INCREDIBLY useful information for future graphics card issues. Now that I know I can remove the wires from those little plastic connectors I don't have to fret so much about them fitting on the card. The electrical tape seems fine, by the way.
Now to just remove that nasty virus :/
Corsair HX 650w
I'm trying to get everyone to take note of the "Marked as solved" option. I think you, as the thread started, has to do it.:cool:
Mine
AMD FX-8150
Dynex 42 inch HDTV
My Book 3TB (USB)
Kingwin KX-1000
Corsair H100
Good to hear Rose, that was a curly one to say the least. It was a good experience for all of us. That's how I learn, by my own blunders.:o
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
