| Windows 7: Need some advice on chosen parts for my new build |
10 Aug 2012
#1 | | |
Need some advice on chosen parts for my new build | My System Specs |
| System Manufacturer/Model Number HP-Pavilion m7755.uk OS Windows 7 Ultimate x32 CPU Intel Core 2 Duo E6600 @ 2.40GHz Motherboard P5LP-LE (Leonite) Memory 3GB PC2-5300 DDR2-667Mhz Graphics Card XFX ATI Radeon HD 4870 1GB Monitor(s) Displays Generic PnP Monitor Screen Resolution 1440 x 900 PSU OCZ Modxstream 600W Hard Drives SAMSUNG HD400LJ Hard drive 400GB |
10 Aug 2012
#2 | | |
It will show a good performance.
There might be only one suggestion,
decrease all the noises of it. | My System Specs | | |
21 Aug 2012
#3 | | |
Yeah i'll sort that out. I might change the processor to a 3570k though, interested in getting into overclocking! | My System Specs | | System Manufacturer/Model Number HP-Pavilion m7755.uk OS Windows 7 Ultimate x32 CPU Intel Core 2 Duo E6600 @ 2.40GHz Motherboard P5LP-LE (Leonite) Memory 3GB PC2-5300 DDR2-667Mhz Graphics Card XFX ATI Radeon HD 4870 1GB Monitor(s) Displays Generic PnP Monitor Screen Resolution 1440 x 900 PSU OCZ Modxstream 600W Hard Drives SAMSUNG HD400LJ Hard drive 400GB |
21 Aug 2012
#4 | | Windows 7 Ultimate x64 SP1 Philadelphia, PA |
The only thing I'd consider is a good aftermarket cooler, and maybe a bigger SSD from Crucial, Samsung, Intel, etc. | My System Specs | | OS Windows 7 Ultimate x64 SP1 CPU Intel Core i7-2600 Motherboard Gigabyte GA-P67A-UD3P-B3 Memory 12 GB Patriot Extreme DDR3-1333 Graphics Card Nvidia GTX 470 Monitor(s) Displays Dell UltraSharp 2209WA PSU OCZ ModStream 700W Case CoolerMaster HAF 912 Advanced Cooling CoolerMaster Hyper 212 Plus Hard Drives OCZ Agility3 240 GB, WD5001AALS, WD7501AALS |
21 Aug 2012
#5 | | Windows 7 Professional 32bit |
A few suggestions I have is to change the ssd. Get like a Intel, Kingston hyperx, or a ocz agility 3 or vertex 3. They are very good drives. I would say the ocz is lower end then the Kingston hyerx but not by much (I have both) with the Kingston ssd I get boot times of like under 10secconds on my i5-2500k system. And about the same on my laptop with the ocz. Also don't waist your money on dominator ram its not worth it. Anything over about 1600mhz there ain't but performance gain. Get something with low latency that's the key. I would also consider getting the sandy bridge CPU instead of a ivy bridge. There is not much performance difference in the to. Plus the sandy can be much cheaper, and the sandy bridge over clock better! | My System Specs | | OS Windows 7 Professional 32bit System Manufacturer/Model Number HP-Pavilion m7755.uk OS Windows 7 Ultimate x32 CPU Intel Core 2 Duo E6600 @ 2.40GHz Motherboard P5LP-LE (Leonite) Memory 3GB PC2-5300 DDR2-667Mhz Graphics Card XFX ATI Radeon HD 4870 1GB Monitor(s) Displays Generic PnP Monitor Screen Resolution 1440 x 900 PSU OCZ Modxstream 600W Hard Drives SAMSUNG HD400LJ Hard drive 400GB |
23 Aug 2012
#7 | | Windows 7 SP1, Home Premium, 64-bit |
If I waded through the rubbish layout correctly, the 2 choices are mostly the same and differ only on these parts:
First package:
Intel Core i5 3570K CPU
MSI H77MA-G43 motherboard, micro ATX
Crucial Ballistix Sport 8GB RAM
Total package price: 770.25; price of just those 3 parts: 281.91
Second package:
Intel Core i5 2500K CPU
Gigabyte GA-Z68AP-D3 motherboard, full ATX
Corsair DDR3 Vengeance RAM, 8 GB
Total package price: 752.44; price of just those 3 parts: 274.81
Personally--I'd go with the first package. The processor is slightly stronger. But I would swap motherboards, using the Gigabyte board from the second package instead of the MSI.
And I'd ditch the Coolermaster PSU in exchange for either of these:
XFX Pro 550 watt Core Edition; 59.99, not yet in stock
Antec High Current Gamer 520 watt; 62.99
My changes would add a total of 10 or 12 pounds to the total price.
Good choice on the Samsung SSD. | My System Specs | | System Manufacturer/Model Number Ignatz Special; 4 speed manual gearbox; factory air conditioning; one of one OS Windows 7 SP1, Home Premium, 64-bit CPU Intel Sandy Bridge i5-2500, not overclocked Motherboard Gigabyte H67A-UD3H-B3, full ATX Memory 4 GB Crucial DDR3-1333 Graphics Card none; graphics are integrated on CPU Sound Card onboard: Realtek ALC892; external: USB Behringer UF0-202 Monitor(s) Displays NEC 90GX2-BK 19" LCD Screen Resolution 800 x 640 Keyboard Leopold Tenkeyless with Cherry Blue switches, USB Mouse Logitech or Microsoft optical wired; either USB or PS 2 PSU Seasonic SS-560KM, modular Case Antec Solo II Cooling CPU: Scythe Big Shuriken; Case: Scythe Slipstream 800 & 500 Hard Drives System: Intel 320 Series SSD, 80 GB;
Backup: WD Caviar Green WD15EADS-00P8B0, 1.5TB Other Info Power consumption of this system, including monitor: 68 watts at idle; 144 watts at full load |
23 Aug 2012
#8 | | |
Quote: Originally Posted by ignatzatsonic If I waded through the rubbish layout correctly, the 2 choices are mostly the same and differ only on these parts:
First package:
Second package:
Good choice on the Samsung SSD. I know I just realised that when I left for work, thinking "Hang on.. i think they were the same"
But thanks for the PSU recommendations. I have no idea about the good PSUs out there but I just picked that one out. I'll be looking for a monitor too, know any good ones under £100?
Oh and one extra thing which could help, but not too bothered about - Are there any good cases which look very unique, like the NZXT Phantom? I want my PC to look a bit like a gaming console in a way, thankss | My System Specs | | System Manufacturer/Model Number HP-Pavilion m7755.uk OS Windows 7 Ultimate x32 CPU Intel Core 2 Duo E6600 @ 2.40GHz Motherboard P5LP-LE (Leonite) Memory 3GB PC2-5300 DDR2-667Mhz Graphics Card XFX ATI Radeon HD 4870 1GB Monitor(s) Displays Generic PnP Monitor Screen Resolution 1440 x 900 PSU OCZ Modxstream 600W Hard Drives SAMSUNG HD400LJ Hard drive 400GB |
23 Aug 2012
#9 | | Windows 7 SP1, Home Premium, 64-bit |
Cases are mostly personal preference. Some are mostly interested in looks. Others in airflow and cooling. Others in drive capacity and overall size. My "good" might be your "hopeless". Antec and Coolermaster are two common and pretty well thought of brands, but you have to carefully look over each model.
ATX cases are going to be a larger and may be easier to work on and cool.
I don't stay up to date on monitors. My current one is 4 years old and has worked perfectly. NEC brand. But monitors are hit and miss too. I read negative comments about nearly any brand. | My System Specs | | System Manufacturer/Model Number Ignatz Special; 4 speed manual gearbox; factory air conditioning; one of one OS Windows 7 SP1, Home Premium, 64-bit CPU Intel Sandy Bridge i5-2500, not overclocked Motherboard Gigabyte H67A-UD3H-B3, full ATX Memory 4 GB Crucial DDR3-1333 Graphics Card none; graphics are integrated on CPU Sound Card onboard: Realtek ALC892; external: USB Behringer UF0-202 Monitor(s) Displays NEC 90GX2-BK 19" LCD Screen Resolution 800 x 640 Keyboard Leopold Tenkeyless with Cherry Blue switches, USB Mouse Logitech or Microsoft optical wired; either USB or PS 2 PSU Seasonic SS-560KM, modular Case Antec Solo II Cooling CPU: Scythe Big Shuriken; Case: Scythe Slipstream 800 & 500 Hard Drives System: Intel 320 Series SSD, 80 GB;
23 Aug 2012
#10 | | |
I agree to be honest. As long as my PC is good, i am fine with everything else. Don't want to make everything so complicated. Thanks for your help either way. | My System Specs | | System Manufacturer/Model Number HP-Pavilion m7755.uk OS Windows 7 Ultimate x32 CPU Intel Core 2 Duo E6600 @ 2.40GHz Motherboard P5LP-LE (Leonite) Memory 3GB PC2-5300 DDR2-667Mhz Graphics Card XFX ATI Radeon HD 4870 1GB Monitor(s) Displays Generic PnP Monitor Screen Resolution 1440 x 900 PSU OCZ Modxstream 600W Hard Drives SAMSUNG HD400LJ Hard drive 400GB Need some advice on chosen parts for my new build problems? All times are GMT -5. The time now is 10:11 PM. | |
