Windows 7: I need help finding parts (capacitors) for a monitor.
17 Aug 2012   #1
Marshall Moore
I have contacted HP. They say they can't help with this.
I need to find out what capacitors fit my HP 2509b monitor. My monitor is flickering and I would like to replace the bad capacitors. I would like to know what possible capacitors are inside of the monitor and order them bad or not. They aren't expensive so if I buy some I don't need that is fine. I would like to have them on hand when I take the monitor apart so I can replace the bad ones at the same time. I would rather do it that way verses taking the monitor apart to find out what capacitors I need and then ordering. I have had no luck searching the web for this information. Please let me know what to order so I can repair my monitor before it goes out completely. Thank you, Marshall Moore
17 Aug 2012   #2
bassfisher6522
Windows 7 Ultimate 64 bit
Your best bet would be to take the monitor apart and find/locate the bad capacitors and get the ID# off of it and look it up that way. I here Radio Shack has a good inventory of such items.
17 Aug 2012   #3
Marshall Moore
You are probably right. That way I can go ahead and fix it the same day. I didn't want to take it apart and have to order the capacitors and wait for them. Good sound advice. Thank you.
17 Aug 2012   #4
A Guy
If they are regular electrolytic capacitors, the value will be right on the caps. IE: 10mf 10v (10 micro farads at 10 volts). These will be common, and likely available at RS unless they are some strange value. It they are another type of capacitor then they would likely only be identifiable by the location in a service manual, such as c910, cross referenced to a part number.
What makes you think it is capacitors? The common capacitor issue (see Capacitor Plague ) usually affects power supplies, and results in trouble turning the unit on. They certainly can have other effects. Is the video flickering only, or are the backlights flickering? Look in the back through the cooling slots and see if the lights are flickering.
Go here and scroll down to Screen flickers, unstable image
http://h10025.www1.hp.com/ewfrf/wc/d...t=5074282#N403
Does that look like it?
A Guy
18 Aug 2012   #5
Marshall Moore
Monitor is flickering
I know it is only a monitor issue. It is flickering. With the monitor disconnected from pc it still flickers. It will stable out after a few seconds. I was only wondering if someone would know how or if I could find out what capacitors are inside without opening it up first. Capacitors are fairly inexpensive so I wanted to buy all possible compatible capacitors without having to physically inspect them first. In a nutshell I didn't want to have to take the monitor apart spot which ones are bad and then order the replacements. If I already had all possible capacitors on hand I could just fix the monitor in an hour or two, thus keeping the down time to a minimum.
I know whats wrong with the monitor. I just was hoping someone may know how I could find this information with research rather than with inspection. Thank you
18 Aug 2012   #6
A Guy
OK...I am a TV tech, but don't have access to any HP manuals (not sure who makes their stuff). You may not be able to physically see which caps are bad. But looks like you have that covered, so wish you luck
A Guy
Need help finding parts for new PC build ($500 budget)
I figured I might as well come to the experts here at SevenForums for some guidance and support on finding parts for my new PC build. I'm working with a budget of $500. I've looked at Newegg and Amazon, trying to find the best deals, but I'm pretty lost as to what grounds to start on. I'd like to...
Hardware & Devices
Secret to finding exact score in reliability monitor
While cleaning up logs, I found this in Event Viewer:Application and Services Logs:Microsoft:Windows:Reliability-Analysis Engine:Operational events: Since the exact score is shown, can a task or gadget be created with this daily log to show the line graph with these numbers?:huh:
Performance & Maintenance
Need help finding parts for computer I'm building
Here are the parts I am working with (parts I bought and will be using in my new PC). Graphics card (EVGA GeForce 9800 GTX+) - http://www.newegg.co...N82E16814130339 Memory (OCZ 4GB (2 x 2GB) DDR2 SDRAM) - http://www.newegg.co...N82E16820227248 Power supply (Ultra LSP750 750 Watts) -...
Hardware & Devices
Not finding my graphics card and monitor after update
After I reformatted windows 7 I notice that it looked funny and that my graphics card was set to standard and my monitor was set to generic pnp monitor. Ive downloaded the graphic card drivers from amd but they still dont show up. Windows 7 Home Premium (x64) Service Pack 1 (build 7601) Dell...
Graphic Cards
Need help finding a good monitor for xbox 360/7 compatible
I want one thats not over $400.20"-35" is fine. Looking for: 10000000:1 contrast ratio 2ms response time 120hz 1080(1920 x 1080) That is just all I know to look for in a monitor.Basicly whatever gives best gaming experiance and also able to work on 7 also.I would really like a 3D,but fell...
Hardware & Devices
Need help finding a good 2560x1600 monitor
Hey guys. Im looking for new monitor at around 26" - 32" at the resolution 2560x1600. or... infact im looking for 3 new monitors at that size, for multi-monitor gaming with ATI eyefinity. i'd be very pleased if anyone could name a few good LCD screens.. thanx a lot guys xD
Hardware & Devices
