Front Panel Audio connector help needed
  1. Posts : 4
    Windows 8.1 Professional x64
    So I basically have a very odd front panel audio connector setup, very confusing, I've made over 10 thread on different forums and non were able to help me.
    I'm using a Gigabyte G31 motherboard GIGABYTE - Motherboard - Socket 775 - GA-G31M-ES2L (rev. 1.x)
    Manual page for the motherboard output can be found below the first image
    The front panel audio connectors consists of:
    Yellow- MIC BIAS
    Green - SPKOUT R
    Peach - MIC In
    Blue - Return L
    Black - Ground
    White - SPKOUT L
    Grey - SPKOUT L
    Much Thanks and appreciation to those who read this read
  2. Posts : 2,606
    Windows 7 Pro X64 SP1
    Your front panel connections aren't odd, but they are old. They are for the AC97 standard.
    Set your onbaord audio to AC97 in the BIOS set-up.
    The AC97 pinouts are here:
    Desktop Boards — Front panel audio header pinouts
    1 Mic In
    2 Ground
    3 Mic Bias
    5 Spkout R
    9 Spkout L
    It looks like the onboard audio doesn't support the Return lines.
    There should only be one Spkout L connector. It's the white (not gray) one.
    Have you really been trying to figure this out for 5 months? Yikes.
    If these connections cause your PC to go up in a fireball, don't blame me.
