Power supply problem? +12V low
  1. Posts : 12
    Windows 7 64 bits
    Hi, I'm having random crashes while playing games with my new custom build and I wanted to know if this could be my PSU's fault. Check this out.
    I've tried everything and I think this is a hardware problem.
  2. Posts : 6,879
    Win 7 Ultimate x64
    Don't rely on software for voltage readings. For starters if the 12V rail was really that low the computer wouldn't even boot. Only reliable way to check the voltages is to use a multimeter,
    What's a multimeter? How to use it to test your PSU rails? (howto) - Dev Hardware
  3. Posts : 26,869
    Windows 11 Pro
    You can also look in bios under Hardware Monitor and see voltages, although Stormy13's way is the most accurate.
  4. Posts : 391
    Windows 7 Ultimate SP1 (32-bit)
    So software readings on voltages are very unreliable?
