Windows 7: Need help choosing new Destktop PC parts for building it!
13 Sep 2012   #11
vaidas3
Windows 7 pro 64bit. (SP1)
Quote   Quote: Originally Posted by addas View Post
I don't want SSD because I put so much data in the desktop, so I need so much space in desktop, and everytime I install a program or game it comes to the C:\Program Files (if C:\ is the installed directory of the OS) which it has the SSD, so is there anyway to make Desktop data to the HDD instead of SSD, and Install programs automatically to the HDD also?
Sorry for this question, but I am a beginner
you can move desktop folder in windows 7 quite easy. open your user folder. (named same as your user name). there you will see contacts, desktop downloads, my documents, my music etc. click properities and choose loccation tab then move it to HDD,
default program files location is harder to change but most programs lets you choose another folder during setup so its not a problem.
13 Sep 2012   #12
ignatzatsonic
My mobo only support some RAMs of 8 GB
If you want 16 GB of RAM, what's wrong with 4 sticks of 4 GB each?
Those memory support lists are NEVER complete. Your motherboard will run fine on some RAM that is not on that list.
Look here:
http://www.crucial.com/store/listpar...treme9&Cat=RAM
Those Crucial RAM modules are guaranteed to work on your motherboard.
13 Sep 2012   #13
addas
Windows 8 Pro with WMC 64-bit
Quote   Quote: Originally Posted by ignatzatsonic View Post
Look here:
Computer memory upgrades for ASRock Z77 Extreme9 Motherboard from Crucial.com
THANKS! I finally found RAMs! but which one you recommend me from the 16GB kit
13 Sep 2012   #14
ignatzatsonic
Look here:
If I were getting Crucial, from that list, and wanted 16 GB, I'd get one of the following:
16GB kit (8GBx2), 240-pin DIMM, DDR3 PC3-12800 upgrades for ASRock Z77 Extreme9 Motherboard, CT3329255 from Crucial.com
above is 8 GB per stick.
Or
8GB Kit (4GBx2), 240-pin DIMM, DDR3 PC3-12800 upgrades for ASRock Z77 Extreme9 Motherboard, CT3273958 from Crucial.com
Above is 4 GB per stick; so get 2 sets of these if you want 4 GB sticks.
The Crucial search tool is highly reliable, so I wouldn't worry about getting any of those listed.
You will see very little if any improvement by moving up to the expensive stuff on that list. PC3-12800 is a good choice.
13 Sep 2012   #15
DeaconFrost
Instead of giving up all that speed of an SSD, why not just move your data to a data drive like most of us? The Desktop is not meant as a storage area. Nothing screams "noob" like tons of icons and folders on the desktop.
That being said, another reason is to keep your data files and the OS/programs separate. It's easier to recover, and keeps you organized. For best results, make your C drive an SSD for your OS and installed programs. Store all of your data on a larger HDD as D.
13 Sep 2012   #16
addas
Now it is time for the video card! who can recommend me a good video card, my budget is $500 MAXIMUM! My mobo support 4-way SLi and 4-way Crossfire!
13 Sep 2012   #17
ignatzatsonic
Take a look here:
Best PCIe Card: $375 And Up : Best Graphics Cards For The Money: September 2012
What card you need has to do with your monitor and resolution. A $500 card might be gross overkill, depending on those issues.
The various brands might differ in warranty, noise level, support, etc.
13 Sep 2012   #18
addas
Well, I want it for playing Battlefield 3, Call of Duty, watching 1080p HD Movies, and watching 3D!
13 Sep 2012   #19
addas
I chose MSI N670GTX-PM2D2GD5/OC GeForce GTX 670
Is it a good video card?
Building my own PC - Parts List please
Hello, I'm considering building and testing my own computer. I've done some extended research on the concern but never got all the information I needed in terms of what are the best parts to get. For now, since this is my first custom-built computer, I don't want to make it big or professional...
PC Custom Builds and Overclocking
Building a random computer out of extra parts
I have a motherboard, Core 2 Duo E7500, 200gb IDE hard drive, 2 sticks of ram, and 3 fans. I have a random 250 watt power supply sitting around. Do you think that would be enough?
Hardware & Devices
building new PC, looking for some recommendations on some parts..
hello i am building my first pc, and i need a few parts and figure i would check here on and get everyone's recommendations for the parts i need. i have posted my list of what i have and what i need... thanks... my build parts list.. Case= RAIDMAX SMILODON ATX-612WBP Black 1.0mm SECC Steel ATX...
Hardware & Devices
Need help finding parts for computer I'm building
Here are the parts I am working with (parts I bought and will be using in my new PC). Graphics card (EVGA GeForce 9800 GTX+) - http://www.newegg.co...N82E16814130339 Memory (OCZ 4GB (2 x 2GB) DDR2 SDRAM) - http://www.newegg.co...N82E16820227248 Power supply (Ultra LSP750 750 Watts) -...
Hardware & Devices
Choosing the parts for a Desktop PC
Thought I'd start a thread for new builders to help them with the Choosing of their parts. Found this article to be helpful for new builders with not much experience. Hope it will help some people Choosing the parts for a Desktop PC | NetworkDictionary Fabe
Hardware & Devices
Part 4: Choosing and Image Strategy and Building Window
More...
News
