Need help choosing new Destktop PC parts for building it!
addas
6:25 AM
Hey!
I need help choosing parts for building a Desktop PC! I will use it for gaming, programming, watching HD movies, and I want to watch 3D (if my budget can).
My budget is $1,500
I want my processor Intel, and i7 if it is good!
These are what I choose for RAM and Storage:
RAM: Corsair XMS3 — 12GB Triple Channel DDR3 Memory Kit
Storage: Seagate Barracuda 7200.11 1 TB Hard Drive
Note: I want to add WiFi adapter, and I want the Mobo to have so much PCI slots!
Note 2: I don't mind if the Mobo is so big, because the case I will choose is Full Tower!
Thanks!
Windows 8 Pro with WMC 64-bitIntel Core 2 Duo T6400
Acer Aspire 4935G
Acer Aspire 4935 Board
1366 X 768
4 mbps
No need to post more than one time.
Windows 7 Home Premium 32-Bit - Build 7600 SP1Intel Core i3-2120 3.30GhzKingston 4 GB DDR3 1333 mhzAMD Radeon HD6670
AMD Radeon HD6670
Asus VE228
1440 X 900
Corsair CX600M == 600 Watt
Three 120 mm Fans
Microsoft Natural 4000
Microsoft Custom Optical 3000
I posted that thread in General Discussion which is in the wrong forum, so I moved it to here and I request to delete the old one!
Acer Aspire 4935G
1366 X 768
4 mbps
Hey!
My budget is $1,500.
Thanks!
Triple channel RAM would be an X58 motherboard (Socket 1366). That's fairly old tech (2008), to the point where it may be hard to find a new Socket 1366 CPU for sale.
It replacement is Socket 2011, X79 chipset. That'd give you quad channel memory. All of the available CPUs for it are I7s:
Newegg.com - Computer Hardware, CPUs / Processors, Processors - Desktops, LGA 2011
If your interest is gaming, you might prefer a Socket 1155 board. That's more of a mainstream line. (Dual channel RAM, but with performance improvements, so that they don't fall so much behind the X58 systems.)
PCI slots are also considered "legacy" interfaces. Newer boards tend to have PCI-E (PCI Express) slots, which are incompatible despite the similar name.
I suggest a little more study before requesting specific recommendations. Sandy Bridge, Sandy Bridge E, Ivy Bridge, SSD, Geforce GTX 6X0, Radeon HD 7XXX, all to come up to date.
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
Thank you bro! I studied again and again and I found Socket 1155 is the best. These what I chose:
CPU: Intel Core i7-3770K Ivy Bridge
Mobo: ASRock Z77 Extreme9
RAM: Patriot Memory G2 Series Extreme Performance Division 2 Edition Enhanced Latency Kit 16 Dual Channel Kit DDR3 1600 (PC3 12800) 240-Pin SDRAM
HDD: Seagate Barracuda 7200.11 1 TB Hard Drive
Video Card: ????
Case: ????
Power Supply: ????
Can you help me choose the best video card and power supply, and nice cool gaming case?
-Video Card : Budget $500 MAXIMUM
-Case: Budget $160 MAXIMUM
-Power Supply: I will pay if it is so expensive, but I want the BEST!
Thanks!
Acer Aspire 4935G
1366 X 768
4 mbps
I think most would tell you to avoid that particular Seagate drive. I think the 7200.11 series had problems. Look for another Seagate, a Samsung, or a Western Digital Caviar Black.
I wouldn't build a machine nowadays without an SSD for Windows and the operating system. Probably a Samsung with 80 to 128 GB capacity. Use the HDD for your data and possibly gaming installations.
You likely would not have problems with the Patriot RAM, but I'd lean toward Crucial, G Skill, or Corsair. 8 GB is enough for nearly anyone, but suit yourself. 1600 is a good speed.
Case is largely personal preference. Some people like windows in the side panel and flashing lights. Others just want build quality and functionality. Get a mid-tower ATX case. Good brands generally: Antec, Coolermaster, Fractal Design, and a few others.
Power supply: if you will have a single powerful video card, look for something in the 500 to 600 watt range from Seasonic, XFX, or certain models from Corsair and Antec. If you might have 2 powerful video cards, look for something in the 750 to 800 watt range from those same manufacturers.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
I don't want SSD because I put so much data in the desktop, so I need so much space in desktop, and everytime I install a program or game it comes to the C:\Program Files (if C:\ is the installed directory of the OS) which it has the SSD, so is there anyway to make Desktop data to the HDD instead of SSD, and Install programs automatically to the HDD also?
Sorry for this question, but I am a beginner :)
Acer Aspire 4935G
1366 X 768
4 mbps
Put your data on the 1 TB hard drive.
Put your operating system and applications on the SSD. I have Windows 7 and 55 applications installed on an SSD--total space occupied is 30 GB.
Windows 7 by itself typically takes about 18 or 20 GB when updated with Service Pack 1.
Gaming applications can take up a lot of space. If your games will not fit on your SSD, you can instead install them to the 1 TB drive without affecting gaming performance.
The SSD will make your PC snappier overall and is the best single thing you can do for it. I'd MUCH rather have an SSD with 8 GB of RAM than only an HDD with 16 GB.
1600 x 900
Antec Solo II
Pale Moon
My problem with RAM is the Mobo, My mobo only support some RAMs of 8 GB and one of them is the Patriot, see the link: ASRock > Z77 Extreme9
and my CPU only support: DDR3-1333/1600 memories!
Any ideas for another RAMs ?
Acer Aspire 4935G
1366 X 768
4 mbps
Thanks! :) I will ask programming team on how changing the Installation Directory!
Thanks!
Acer Aspire 4935G
1366 X 768
4 mbps
you can move desktop folder in windows 7 quite easy. open your user folder. (named same as your user name). there you will see contacts, desktop downloads, my documents, my music etc. click properities and choose loccation tab then move it to HDD,
default program files location is harder to change but most programs lets you choose another folder during setup so its not a problem.
Windows 7 pro 64bit. (SP1)Intel core I5 24008GB DDR3 KingstonGigabyte GF GTX650OC
Self Built PC
Intel core I5 2400
Gigabyte H61
8GB DDR3 Kingston
Realtek HD audio
LCD 20"
1600x900
INTEL SSD 320 80GB +Seagate 7200.12 1TBx3
Coolermaster RX450W
Coolermaster atx case
stock cooler
logitech
logitech
FTTD 100mbps
1600 x 900
Antec Solo II
Pale Moon
If you want 16 GB of RAM, what's wrong with 4 sticks of 4 GB each?
Those memory support lists are NEVER complete. Your motherboard will run fine on some RAM that is not on that list.
Look here:
Computer memory upgrades for ASRock Z77 Extreme9 Motherboard from Crucial.com
Those Crucial RAM modules are guaranteed to work on your motherboard.
THANKS! :party: :cool: I finally found RAMs! but which one you recommend me from the 16GB kit
Acer Aspire 4935G
1366 X 768
4 mbps
Look here:
If I were getting Crucial, from that list, and wanted 16 GB, I'd get one of the following:
16GB kit (8GBx2), 240-pin DIMM, DDR3 PC3-12800 upgrades for ASRock Z77 Extreme9 Motherboard, CT3329255 from Crucial.com
above is 8 GB per stick.
Or
8GB Kit (4GBx2), 240-pin DIMM, DDR3 PC3-12800 upgrades for ASRock Z77 Extreme9 Motherboard, CT3273958 from Crucial.com
Above is 4 GB per stick; so get 2 sets of these if you want 4 GB sticks.
The Crucial search tool is highly reliable, so I wouldn't worry about getting any of those listed.
You will see very little if any improvement by moving up to the expensive stuff on that list. PC3-12800 is a good choice.
1600 x 900
Antec Solo II
Pale Moon
Instead of giving up all that speed of an SSD, why not just move your data to a data drive like most of us? The Desktop is not meant as a storage area. Nothing screams "noob" like tons of icons and folders on the desktop.
That being said, another reason is to keep your data files and the OS/programs separate. It's easier to recover, and keeps you organized. For best results, make your C drive an SSD for your OS and installed programs. Store all of your data on a larger HDD as D.
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
Now it is time for the video card! who can recommend me a good video card, my budget is $500 MAXIMUM! My mobo support 4-way SLi and 4-way Crossfire! :)
Acer Aspire 4935G
1366 X 768
4 mbps
1600 x 900
Antec Solo II
Pale Moon
Well, I want it for playing Battlefield 3, Call of Duty, watching 1080p HD Movies, and watching 3D!
Acer Aspire 4935G
1366 X 768
4 mbps
I chose MSI N670GTX-PM2D2GD5/OC GeForce GTX 670
Is it a good video card?
Acer Aspire 4935G
1366 X 768
4 mbps
