Problems with wireless mouse.
  1. Posts : 31
    Windows 7 Home Premium 32bit.
    I have a dual OS HP laptop (Windows 7 & Ubuntu 12.04),The Ubuntu was added last weekend. The problem is that with the Microsoft wireless mouse dongle plugged in the computer refuses to boot (loud bleeping sound) unless I hold down the ctrl key, then I can only load windows 7.
    With the dongle out there is no problem,I have used the mouse for over two years booting with or without the dongle inserted and I am sure it worked OK after loading Ubuntu.
    Any suggestions please ?.
    Regards
    Northerner.
  2. Posts : 6,243
    Hi Northener, Have you checked the battery ?
  3. Posts : 31
    Thanks for replying.
    Changed batteries when problem was observed,no improvement.
    Northerner
  4. Posts : 6,243
    Northerner, Is the 1st boot device set to boot the HDD or is it set to boot either CD/DVD or USB 1st ?
  5. Posts : 31
    Order of boot:
    1/internal CD/DVD drive.
    2/ Internal hard drive.
    3/ USB drive.
    I have tried all the options but still problems.
    Regards
    Northerner
  6. Posts : 10,200
    help us to help you:
    Update your SevenForums System Specs
    User CP (located on the top menu bar) |
    Your Profile | Edit System Spec
    (left-hand column)
    To gather info, use Speccy (my favorite) or SIW or System Info
    In the System Manufacturer Block, enter:
    Ř Manufacturer and Model OR Custom build.
    Ř ADD the word laptop, desktop, netbook or tablet.
    For example:
    Toshiba Satellite L305D notebook.
    Provide full windows version info, for example:
    Use the “Other Info” block for Optical Reader,
    Mouse, touchpad, wifi adapter, speakers, monitor, etc
    Scroll down and click on SAVE CHANGES.
    With Speccy, you can select with your mouse/touchpad info from the display
    and paste that info into your specs.
    SIW is a marvelous program, but the free version does not offer
    this capability.
