Windows 7: Problems with wireless mouse.
01 Sep 2012   #1
Northerner
Windows 7 Home Premium 32bit.
I have a dual OS HP laptop (Windows 7 & Ubuntu 12.04),The Ubuntu was added last weekend. The problem is that with the Microsoft wireless mouse dongle plugged in the computer refuses to boot (loud bleeping sound) unless I hold down the ctrl key, then I can only load windows 7.
With the dongle out there is no problem,I have used the mouse for over two years booting with or without the dongle inserted and I am sure it worked OK after loading Ubuntu.
Any suggestions please ?.
Regards
Northerner.
01 Sep 2012   #2
pebbly
Hi Northener, Have you checked the battery ?
01 Sep 2012   #3
Northerner
Thanks for replying.
Changed batteries when problem was observed,no improvement.
Northerner
01 Sep 2012   #4
pebbly
Northerner, Is the 1st boot device set to boot the HDD or is it set to boot either CD/DVD or USB 1st ?
01 Sep 2012   #5
Northerner
Order of boot:
1/internal CD/DVD drive.
2/ Internal hard drive.
3/ USB drive.
I have tried all the options but still problems.
Regards
Northerner
01 Sep 2012   #6
karlsnooks
help us to help you:
Update your SevenForums System Specs
User CP (located on the top menu bar) |
Your Profile | Edit System Spec
(left-hand column)
To gather info, use Speccy (my favorite) or SIW or System Info
In the System Manufacturer Block, enter:
Ř Manufacturer and Model OR Custom build.
Ř ADD the word laptop, desktop, netbook or tablet.
For example:
Toshiba Satellite L305D notebook.
Provide full windows version info, for example:
Use the “Other Info” block for Optical Reader,
Mouse, touchpad, wifi adapter, speakers, monitor, etc
Scroll down and click on SAVE CHANGES.
With Speccy, you can select with your mouse/touchpad info from the display
and paste that info into your specs.
SIW is a marvelous program, but the free version does not offer
this capability.
2.4 Ghz wireless keyboard mouse driver not found (Penguin mouse)
I got a wireless mouse Penguin Ambidextrous Vertical Mouse | Posturite. It is supposed to use generic windows 2.4 Ghz adapter. However, windows 7 is unable to find any drivers. The screenshot of device manager is appended. I tried various other ways e.g. take out other USB devices, reboot etc. I...
Drivers
BSOD, mouse freezes &reboots possibly after new MS wireless KB & mouse
I am still experiencing system freezes possibly triggered by mouse movement. Still reading a lot here but asking for help. New zip attached as Whiskey7a.... grr system froze while typing here (and moved mouse) I have tried system repair sfc/scannow to no effect.... All drivers just...
BSOD Help and Support
Microsoft Wireless Arc Mouse problems
Hello everyone, I've been having problems with two of my Wireless Arc Mice from MS. It only occurs when using this computer. The problem is.. When I use my mouse, sometimes it'll just stop taking input (moving the cursor) and it will take a bit before it'll start taking input again. Now,...
Hardware & Devices
Wireless mouse problems
Hello. I'm having problems with my logitech cordless wireless mouse. The mouse has worked fine for the couple months I've had this computer and a few years I had my last computer. Recently, the mouse stopped working. When I plug in the hand receiver most of the time nothing happens but sometimes a...
Hardware & Devices
wireless mouse problems
ive got a Microsoft wireless keyboard 6000 v3.0 and mouse 6000 v2.0 it says on Microsoft page they are compatible with win 7 but im having some problems like not being able to click or my auto scroll not disabling also my alt tab screen to change window keeps popping up ive tried plunging the...
Hardware & Devices
Microsoft Wireless Mouse Problems
I picked up a Microsoft Wireless Mouse/Keyboard Combo (Wireless Optical Mouse 2000), and on my old wooden desk, it worked great. I picked up a Z-Line Legacy Glass desk, and ever since then, the mouse is nothing but problems. Since its a glass desk, I bought a Mouse pad. The pointer essentially...
Hardware & Devices
