Windows 7: USB 3.0 slow read & write speed
03 Sep 2012   #1
umairulhaq
Windows 7 Ultimate 64 bit
Hello,
I have 4gb and 16gb kingston DT 101 usb....both had slow read & write speeds on fat32(defulat format)..
-write speed 4-6mb/sec
-read speed 25mb/sec appx
When i format it to NTFS, it writes initially at 100mb/s and then suddenly slows down to appx 15-20mb/s... and sometimes it gets stuck somwhere in the middle or on 99% and when i cancel it it start cancelling but doesnt end up, and end ups by removing usb or by logging off... when i copy from usb to harddisk in ntfs format, its working f9...
Why there is problem in writing???
Any help will b appreciated... Thanx in advance
(I have dell inspiron n5520 core i5, 4gb ram, with win 7 ultimate 64bit... my laptop has usb 3.0 ports (all 4 ports).... i have updated drivers and windows... i have also set my usb to better performance from device manager... there is no problem sign in device manager)
03 Sep 2012   #2
GeneO
Those DT 101 are USB 2.0 drives, they will only go at USB 2.0 rates. USB 2.0 at beast is about 35 MB/s on reads but typically 25 MB/s. And these 4GB 101 are not particularly good performers:
http://www.legitreviews.com/article/994/2/
The Kingston site specs say 10 MB/s read, 5 MB/s write.
If you want USB 3.0 speeds you need to get good USB 3.0 sticks.
HDD Write Speed Extremely Slow
So a couple months ago i started a download for a game on steam but when i was checking it, it would download at 400kb for like 10 secs and say busy writing to disk for a whole minute i have 50DL and 4UP and steam usually downloads at a steady 6Mbps I checked my main HDD write speed and it was...
Hardware & Devices
Slow SSD (Intel) write speed
I use my ssd since a year and since a few days the performance drops extremly! First sceenshot is atto with initial settings ... (very slow!) Second, with a little changed settings .... (upper right corner!) and finally a Image with the ASS Tool Infos ... I tried the bench with enabled or...
Performance & Maintenance
DVD Drive: Write Speed Too Slow
I have a Toshiba Satellite laptop with a MATSHITA UJ8A0AS DVD RAM Drive. When I first got my laptop, it would burn up to 8x however recently it has been burning slower (a few months ago only going to 4x) now it is "maxed" at 2.4x, which would be ok if windows explorer and other DVD programs...
Hardware & Devices
Extremely slow HDD (read and write)
Hello. I'm having problems with an almost full (97% full) Western Digital 1.5 TB 7200 RPM HDD. If I try to read from it or write to it, it takes so long it's practically unusable. Even just loading up a directory in Windows Explorer may take multiple seconds. I ran HD Tune Pro and the Health...
Hardware & Devices
HDD slow write, fast read
Have 4 HDDs mounted in case. 3 of them are fine. The WDC W20EADS tests at an average write speed of 1MB/s, read is 80MB/s. Every now and then it comes right and the write speed is also around 80MB/s. Stuck in the bottom of the case it runs quite warm 35C to 45C. Is the drive failing, or...
Hardware & Devices
Slow USB write speed
hi guys. i've recently got a Kingston DataTraveller 101 (4 gb) which says that its read and write speed is 10 mb/sec. I'm running windows 7 and when i tried copying a 3 gb file in the pen drive i was getting a speed of just 5 mb/s. is there any problem or is that normal. regards kranika
Hardware & Devices
