Windows 7: Battery plugged in, not charging. Not the normal problem.
29 Sep 2012   #1
Windows 7 Home Premium 64 bit
I've got a problem, my battery wont charge.
I used to get this, but re installing ACPI-Compliant Control Method Battery would normally solve this problem. Now after i remove ac, the laptop shuts down. I also got a screen once that saying my battery can now store less. When I click on the battery icon, it says plugged in and not charging.
Please help,
Paradoxex
29 Sep 2012   #2
win 7 ultimate
nottingham
Hi ParadoXeX, How old is the battery? Do you "condition" the battery ? do you Know for definate the laptops charger board is working ? have a look here see if this helps in any way What To Do If Your Laptop Is Plugged In But Not Charging | PCMag.com
29 Sep 2012   #3
Windows 7 Ultimate 64 bit
NC
What's the brand of your laptop? Some laptop manufacturers have special diagnostic software to test the battery of the laptop to see if it can be salvaged or replaced.
29 Sep 2012   #4
It is an HP DV6, It's the battery that came with the laptop, about maybe 2 years old now?
What do you mean by condition the battery? I'll look up the site now.
 Battery plugged in, not charging. Not the normal problem. problems?
Similar help and support threads for: Battery plugged in, not charging. Not the normal problem.
Solved 96% Battery plugged in but not charging Performance & Maintenance
Solved Battery Meter shows CMOS battery not charging Hardware & Devices
Solved Laptop Battery - Plugged in, not charging. Hardware & Devices
Solved SONY battery issue Its showing 44% available(plugged in , charging) General Discussion
"Plugged in, Not Charging" - Battery Hardware & Devices
