How do I fix function keys problem?
semitho
5:17 AM
Something is wrong with my fn key and F1-F12 keys?
Suddenly it seems like my F1-F12 keys are using different keys.
For example, when I press F1, I get a screen output switch thing. F2 disables my wifi. F3 uses the A key. F8 uses my Q key, and F9 uses my G key.
How do I fix this? I want to use F5 to refresh web pages but it doesn't work.
I am using a Dell Inspiron 17R N7110 model
Dell/Inspiron 17R N7110
Is there an f.lock key on the keyboard in question?
It overrides the fn key. I have no idea what pressing both at the same time results in. Likely the problem you are experiencing though.
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
I don't think there is, I only see NumLk
Numberlock sometimes works in conjuncture with the function key. Try pressing Fn + Shift + Numberlock
Or any other combinations like Fn + Ctrl +Numberlock
Or maybe even just Fn + Numberlock... not sure which will work...
Win7 Home Premium 64xIntel Core 2 Duo P7450 / 2.13 GHz (2.29 with ...4 GB PC-6400 Hyundai (2X2) at 800MhzNVIDIA GeForce GTX 260M 1GB DDR3 VRAM
ASUS G60-RBBX05
16" LED Backlit
ASUS G60 Laptop
Mobo: GIGABYTE GA-990FXA-UD3
none of them work :c
when I try using the on screen keyboard, it works though
Have you tried any other keyboards? it might be a problem with the keyboard itself. like if anything spilled on it, the contacts can get crossed.
ASUS G60-RBBX05
16" LED Backlit
ASUS G60 Laptop
I used an external keyboard and everything works fine-- I think it's my laptop keyboard. I never eat or drink near my computer though...
It could be something goofy has gone wrong with the software or driver that supports it.
You could try reinstalling that. It should be available on the manufacturer's website.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
If you need to replace it, there are video tutorials on how to remove the keyboard this one is for full disassembly, but it has the keyboard part in it:
Note: if its still under warrentee then probably send it in for repair
ASUS G60-RBBX05
16" LED Backlit
ASUS G60 Laptop
