Help PLZ!!! Weird Problem with my installed Memory !!!!!!!!
sylvans
3:42 AM
Mohterboard : Ep31-Ds3l rev:2.1
Harddisk : 320 WD sata
Vga : 1GB 9500GT
Processor : inter Core2due E7500 @2.93GHz
memory : 2 rams 1x giga each , and onther 2 giga ram
system type : Windows 7 ultimate 64bit
this how my windows read my memory , i don't know why and how its 3gb usable only ...... i need help plz :)
Only 3gb Usable out of 4gb Memory
My bios Version is (FC)
Intel Core™ 2 Duo E7500 2.93GHz 3MB Wolfdale 45nm R0 65W 1066 (FC)
Plus FDC bios still beta >.< i dont know what i can do , help plz:)
What does it say in msconfig under the boot tab - advanced options - maximum memory. Is the box checked or unchecked? What does it say for number of processors?
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
it said 3072 but i can't tick to maximum as 40xxish , it returns to (0) when i press ok :) thx for rply
plus when i start my pc i press Del , at the Bios Screen , it read my memory as 3072 also
i install my ram as DDR2 1 DDR2 3 DDR2 2 hope u help me
Doe you have 3 sticks or 4 installed?
Custom built
On board RealTek HD
1600 X 900
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
3 sticks 1=2gb 2 every1 =1 gb all equals to 3 sticks of ram
You may want to check your motherboard manual for supported memory configurations. Like most motherboard manufacturer, Gigabyte probably recommends that the same brand, capacity, speed, chips are used. At times, Windows will not detect correctly, if the memory cards are mismatched...
Windows 7 64-bit, Windows 8.1 64-bit, OSX El ...Intel i5-3350P 3.1 GHz16 GBs GSkill SniperRadeon HD 7850
Custom built at Home
Windows 7 64-bit, Windows 8.1 64-bit, OSX El Capitan, Windows 10 (VMware)
Gigabyte GA-Z77X-UP5 TH
Radeon HD 7850
VIA HD Audio
Dell U2410 24"
1920x1200
1 x Intel 520 240 GBs
1 x Seagate 1TBs SATA 2.0,
1 x Seagate 1TBs eSATA 2.0
Thermaltake 850W
Antec P183
Noctua NH-D14 Heatsink 2 x 120mm fans, 4 x 120mm case fans
Dell Multimedia keyboard
Logitech Trackball
28.5 Mb/s
DDR2 DIMM sockets supporting up to 4 GB of system memory
Dual channel memory architecture
Support for DDR2 1066/800/667 MHz memory modules
Because of chipset limitations
*To avoid the system being unable to start or the memory being incorrectly detected, if only one memory module is to be installed, we suggest that you install it on the DDR2_1 or DDR2_3 socket.
*To install two memory modules, we suggest that you install them on the DDR2_1 and DDR2_3 sockets, when the DDR2_2 or DDR2_4 socket is populated with a DDR2 1066 MHz memory module, the memory speed will be downgraded to 800 MHz).
*when using FSB 1333 MHz CPU with populating all DIMM sockets, memory frequency will be reduced from the original, and system instability or incorrect detection of memory module may be occur.
(Please refer "Memory Support List" for memory support information)
GIGABYTE - Motherboard - Socket 775 - GA-EP31-DS3L (rev. 2.1)
EP31-Ds3L i think it supports >.< 4gb of ram
the 2 sticks of ram are=2GB are : Apogee DDR2 667 1GB pc2 5300 and ,
the 1 stick of ram =2GB DDR2 800 i think not sure but is 2 Gb
This is why,
The system memory that is reported in the System Information dialog box in Windows Vista is less than you expect if 4 GB of RAM is installed
When the physical RAM that is installed on a computer equals the address space that is supported by the chipset, the total system memory that is available to the operating system is always less than the physical RAM that is installed. For example, consider a computer that has an Intel 975X chipset that supports 8 GB of address space. If you install 4 GB of RAM, the system memory that is available to the operating system will be reduced by the PCI configuration requirements. In this scenario, PCI configuration requirements reduce the memory that is available to the operating system by an amount that is between approximately 200 MB and approximately 1 GB. The reduction depends on the configuration.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
so i have to remove 1 stick of ram , and go on 3 gb of ram only
thx for help
1 last question , where should i install 1st in DDR2 1 the 2gb ram or the 1 gb ram , or it wont matter
i'll remove the other 1 gb ram , and stay with 3gb ram only
should i upgrade bios to Fdc , or it wont matter also
Intel Core™ 2 Duo E7500 2.93GHz 3MB Wolfdale 45nm R0 65W 1066 FC
giga byte did't upgrade it even , so should i keep it (Fc)?
