Windows 7: External Hard Drive Problem :(
22 Oct 2012   #1
Tariq Mahmood
Window 7 Professional x64
I think Mere Hard Drive mai Virus hai. Hard Drive ki space y show kar rai hai k external hard mai data hai . but in folder wo show nai ho rha ......
My Hard drive show data space in properties . But Data not show in drive . I this Its virus. Kindly recomend good Antivirus software
22 Oct 2012   #2
marsmimar
Hello Tariq and welcome to Seven Forums.
You can try the free version of Malwarebytes. It is highly recommended on this Forum. After installing on your computer make sure you get the latest updates. Select Full Scan. Then select which drive(s) you want to scan. A full scan could take over an hour.
Malwarebytes : Malwarebytes Anti-Malware removes malware including viruses, spyware, worms and trojans, plus it protects your computer
22 Oct 2012   #3
Slartybart
Tariq: Eset online scanner is also very well regarded. It is also free. I would run both Malwarebytes and Eset scanner, but not at the same time. run one, then the other.
These are both scanners, not real-time protection.
Consider free AV - Microsoft Security Essentials, or Avast, or AVG. You only need one, more than one AV program can cause issues as they tend to compete for resources and they might consider the other application a security risk. So only run one real-time AV program on your system.
External Hard Drive problem
When I connect my 1TB Buffalo MiniStation to my PC, -it does not show up on 'My computer'. The 'safely remove device' option is there. The device is also visible in Disk Management. I googled around for some time and the most common solution offered by others was to assign a drive letter to the...
Hardware & Devices
External hard drive problem
My Xternal hard drive that I have had for awhile,is being dropped while I am using it.Then when I go back to open it again,it is not even listed on my computer. I have windows 7 ultimate 64.It is a small drive HDDgear is the name.I have un plugged it and tried it on another computer with XP and it...
Hardware & Devices
WD External hard drive problem from no where?
Ok. Well my external hard drive is about 3 months old. I have videos, pictures and my itunes library on it. It has been working without a flaw up until now. I plug it in, type in password, click the vid or pic I wanna view and i get "discovering" or "cant find file/cant read file or cant read...
Hardware & Devices
External Hard drive problem
I have a 2.5 sata 250gb hard drive from a laptop with a broken screen. I bought a enclosure for it so I could use it as a external hard drive. During the process of backing up and clean up I apparantly deleted something important because it started saying the drives (the hard drive has a recovery...
Hardware & Devices
hello,,, my Ext. HD is not working,,, until now, it said that it's not recognized... but the disk is running...... finish for checking cables but it's still not working...updated the driver, still not working i always keep it in the safe place,.... i give you the screenshot......
Hardware & Devices
I have an external hard drive and I plug it in and the computer recognizes it and it appears in My Computer as drive J, but when I try to save something to it I get the following error: I'm logged in as administrator and have never gotten this error message before help! Edit: If I drag the...
Hardware & Devices
