Windows 7: Pc power up without press power button
23 Oct 2012   #1
nackgr
win 7
Hello
Suddenly pc doesnt boot up we change with new psu and from that time pc power up by the time we connect the psu with power ,
i remove all cables i left connection psu with motherboard but still the pc power up by him self , i remove the cpu and then didnt power up ...
what the problem
23 Oct 2012   #2
Carl Lawrence
Dual-boot: Windows 7 HP 32-bit SP1 & Windows XP Pro 32-bit SP2.
Go into the bios and find something like "Self Power on" and disable it, then it shouldn't happen anymore.
Shut down computer, remove all power sources, hold down power button
Why does shutting down the computer, removing the AC Adapter, removing the battery (if it is a laptop), and holding down the power button for 30 seconds fix problems in one's computer. I was recently corrected in a post of mine that this does not actually do anything unless one removes the 3 volt...
Hardware & Devices
Start and message cant log on security press esp or power key
Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation Code: 0 Cached Online Validation Code: 0x0 Windows Product Key: *****-*****-PHMYG-8P49Q-9226R Windows Product Key Hash: oeHsWoa/t6LkJJJczOsuqlDB1Bg= Windows Product ID:...
Windows Updates & Activation
Power button and sleep button
Please let me know the difference between sleep button and power button Is sleep button the one which will be on the keyboard? On the CPU there will 2 buttons one will be to start the computer and another one to restart computer? Can these buttons be used to work like to enter in sleep...
General Discussion
power button log off GPO
Hi all, I was wondering if there is a win 7/8 GPO tweak to FORCE a log off when the Power Button is pressed ? ex. if a user is logged on and has an unsaved document, the windows will not log off, it will ask to wait. I need to FORCE log off... any ideas ? thanks
General Discussion
Press power button, blue screen after beep, then fine.
Hey guys, just a shot in the dark question, but: I put a fresh install of windows 7 64-bit on this PC I built for my sister, and everything appears to go fine. However, after updating the bios, and installing the gfx card drivers, she tells me that when she presses the power on button, she gets...
BSOD Help and Support
power button
Can anyone tell me why my power button has disappeared from vista start menu?
General Discussion
