Windows 7: Problem after problem!
29 Oct 2012   #1
Windows 7 64 bit Home Premium
I went to start up my computer today and when I did it my stupid power on button got stuck on my case (Phantom 410)
I fixed that then I when I turned it on it said
Main BIOS is corrupted. System will recovery
from Backup BIO. Please don't turn off power
or reset system. It might take few minutes.
I have a B75M-D3H Motherboard.
Should I be worried? Or did it glitch because of power button? I just got this computer september 9th 2012.. Shouldn't be messing up.
I AM GETTING FED UP WITH MY COMPUTER.
29 Oct 2012   #2
SecretCity
How the heck can power button be stuck in case? And how did you fix that?
Did you or someone else let laptop fall on floor
Is bios located just behind power button?
29 Oct 2012   #3
Windows 7 Ultimate 64 bit
NC
After all that....does it start/boot up normally now.
29 Oct 2012   #4
Yes it is fine now
And it is a desktop. The power button got stuck halfway in (phantom 410 case)
I'd like to fix the main bios if possible.
What do I do if it breaks again?
29 Oct 2012   #5
NC
I have heard that power buttons have got stuck before....the switch and spring inside the button is faulty or going bad and can and should be replaced.
Seeing that the case is fairly new and mordern, if it is still under warranty, I would consider having it replaced.
Now, your BIOS should be fine since it repaired itself and I wouldn't worry about it. If you want to you could see if there is a BIOS update and install that. But be very careful when doing so. If not done correctly you can brick your system (fry it) rendering it useless.
29 Oct 2012   #6
NC
There are quiet a bit of driver and BIOS updates for that mobo.
GIGABYTE - Motherboard - Socket 1155 - GA-B75M-D3H (rev. 1.0)
29 Oct 2012   #7
Quote   Quote: Originally Posted by bassfisher6522 View Post
Ok well would it be possible to switch to back main bios again to see if it is infact corrupted?
And i think I may have pressed down too hard on the power button. when i press it gently it works fine
29 Oct 2012   #8
NC
They are one and the same...a copy that is set aside for just such problems. No different then having the hidden partition of a retail PC that has the OS on it to restore the PC to factory condition in case of a fatal error/corruption. The same for the BIOS backup.
29 Oct 2012   #9
What happens if it messes up again though?
Did the backup bios copy itself to main bios?
30 Oct 2012   #10
Its fine still.. but im worried about it
 Problem after problem! problems?
Similar help and support threads for: Problem after problem!
problem event name startup repair offline - slightly different problem General Discussion
Solved Moving windows/icons down problem!! Move right/left/up - no problem General Discussion
Desktop icon problem, programs in start menu problem and more... General Discussion
Cute Html problem and Video full screen problem Software
Windows Media Player Problem - Sound/skipping problem. Music, Pictures & Video
