Problem in partitioning the hard drive
  1. Posts : 11
    Windows 7 home premium 32bit
    Hi experts,
    I am using 284 GB hard drive in my laptop.there is two drives now C and G.drive C is 184 GB but only occupied by 54GB but when i tried to shrink the drive only 21 GB is available to shrink.i want new drive with 100 GB,could you please any one help me to partition?
    Note:i tried defragmentation but still i am getting the same available shrink size as 21 GB.
    What should i do?
    Please give the detail explanation.
    Thanks in advance.
    Cheers
    Tamil
  2. Posts : 6,292
    Hello Tamilarasan23. Welcome to the forum.
    That behavior is a well know problem with Windows. The OS will not allow you to shrink the partition the OS is on to any size you want. The reason is because Windows wants your Page File, and other system files, in an 'unmovable' location on the disk. The OS will not shrink the partition beyond the location of these files.
    But they can be moved and the partition can be shrunk without affecting the operation of the OS. Just not with Windows.
    Most folks here use Partition Wizard to do this job. It is an easy and relatively safe procedure. Just download and create bootable media (CD or USB), because you can't shink C: from within the OS while it is running.
    Free Partition Magic alternative, partition manager freeware, partition magic server, partition magic Windows 7 and free Partition Manager software for Windows 7/8/VISTA/XP/2000 and Windows Server 2003/2008/2000.
  3. Posts : 11
    dear tevblen,
    thanks very much but what is the use of bootable media?what it will do? what is the system requirement to download?after download it should i download the partition wizard and do partition?please guide me
  4. whs
    The bootable CD of Partition Wizard is self sufficient. It brings it's own mini windows. Just download the .iso and burn it to CD. Then boot with that CD and you will see.
    If you don't know how to use it, click on the Help icon.
  5. Posts : 11
    Thanks expert but i don't have cd drive to boot only usb port in my laptop
  6. whs
    Then use the USB stick version.
  7. Posts : 7,055
    Windows 7 Home Premium 32 bit
    You can create a bootable pendrive with the downloaded ISO.
    Use Rufus Rufus - Create bootable USB drives
    Plug in your pendrive, run Rufus, select ISO image in the dropdown list, select the ISO and click on start.
    Thamizhukkum amudhendru per,
    andha thamizh inbathamizh yengal uyirukku ner, uyirukku ner,
    Tamil is synonymous with nectar,
    Tamil , sweet Tamil, is equivalent to our soul, it is our soul,
  8. Posts : 11
    Dear experts Thanks very much for your precious help...I will try wit all of yours input.
    @jumanji:mikka mikka nandri anna...vazhga valamudan
  9. whs
  10. Posts : 7,055
    ^ Yes, of course it can be created in the aforesaid manner. But it involves installing Partition Wizard on to the PC and then creating the bootable pendrive from it.
    Creating the bootable pendrive from the bootable ISO using Rufus is much simpler. Rufus itself is a .exe file needing no install. Further the whole process is fast and the pendrive will still be usable as before to transfer data.( I am not sure of the one created from within the Partition Wizard.)
