Computer does not start, LED light on for motherboard...
Cr00zng
Pro User
1:59 AM
With Sandy visit in my area, I've lost power couple of times with the computer being on. It had no issues starting it up, other than Windows complaining about not being shut down gracefully.
While I have had power for the last 4-5 days, yesterday the utility power went out with a big boom. I have the generator running and now the computer does not start at all. The LED light is on for the motherboard, indicating that the power is on for the board. Pushing the power on button results in nothing, the system does not start up.
The generator powers the whole house and this computer did work just fine previously when using generator power. The system also had some issues with not maintaining the BIOS settings, as described in a previous thread:
http://www.sevenforums.com/hardware-devices/254079-bios-battery-backup-issue.html
There had been no changes made to the system hardware recently, other than replacing the BIOS battery end of this September.
The LED light goes out in 3-5 seconds, when the PS power switch is shut off and comes on instantly when turned on.
The chances are that either the power supply and/or the motherboard crapped out. Is there a way to positively identify which component is faulty? It does make a difference. If it's the motherboard, I am building a new computer. Conversely, replacing the power supply would save this computer, at least for awhile.
I am planning to get a new power supply today:
Thermaltake SMART Series 850Watt ATX Power Supply SP-850M - Best Buy
It this one doesn't resolve the issue, I'll use it in my soon to build new machine.
I'd appreciate any other suggestion for troubleshooting this issue.
TIA...
Windows 7 64-bit, Windows 8.1 64-bit, OSX El ...Intel i5-3350P 3.1 GHz16 GBs GSkill SniperRadeon HD 7850
Custom built at Home
Windows 7 64-bit, Windows 8.1 64-bit, OSX El Capitan, Windows 10 (VMware)
Gigabyte GA-Z77X-UP5 TH
Radeon HD 7850
VIA HD Audio
Dell U2410 24"
1920x1200
1 x Intel 520 240 GBs
1 x Seagate 1TBs SATA 2.0,
1 x Seagate 1TBs eSATA 2.0
Thermaltake 850W
Antec P183
Noctua NH-D14 Heatsink 2 x 120mm fans, 4 x 120mm case fans
Dell Multimedia keyboard
Logitech Trackball
28.5 Mb/s
If the mobo light comes on it possibly isn't the psu. Could be your cpu or another part of the mobo is fried.
Windows 8 64-bit (6.2, Build 9200) (9200.win8...AMD Quad-Core A10-4600M APU 2.3Ghz Turbo to 3.48GB DDR3AMD Radeon HD 7660G
HP C2N70UA#ABA Laptop
Windows 8 64-bit (6.2, Build 9200) (9200.win8_rtm.120725-1247)
8GB DDR3
AMD Radeon HD 7660G
Altec Lansing with SRS Premium Sound
17" Laptop HD Display (720p)
1600*900
750GB (5400 RPM), with smart protect
Western Digital 1TB Passport
HP Cool Sense
Island Style
Logitech 625 Wireless
30MBps
Provided that turning on the PC turns on the PSU...
Wouldn't the fans kick-in even if the motherboard and/or the CPU fried? There are fans that are directly running from the PSU.
Radeon HD 7850
VIA HD Audio
Dell U2410 24"
1920x1200
Thermaltake 850W
Antec P183
Logitech Trackball
28.5 Mb/s
