Belkin USB Wireless Adapter Problems...
Page 1 of 4 123 ... LastLast
  1. Posts : 27
    Ok i installed windows 7 few days back the RC and i tried to install the Belkin USB Wireless adapter drive, now its installed and i restarted my computer now after restart and login it will connect to the internet for like 2-5mins and then disconnect when i try fix it totally looses connection and there no way getting it back unless i restart it again.
    I find it strange how it works for few mins and just doesn't work at all and tottaly loses connection, anyone have any ideas why it isn't working?
    Thank you,
    Regards,
    Mark
  2. Posts : 28,845
    Win 8 Release candidate 8400
    ibanksy
    Try dis-abling IPv6 support in sharing and network>adapter>pick adapter>dbl click>properites>uncheck ipv6
    let us know how it turns out
    ken
  3. Posts : 27
    Done what you said, tried to go on IE 8 and it all disconnected now in the bottom right hand corner i have a yellow warning sign saying it's disconnected like i normally get, unless i restart the computer and login again then it connects again.
    Thank you for your suggestion :)
  4. Posts : 28,845
    IB
    start>search>type cmd>type ipconfig /all Use built in snipping tool (type snipping in search) to take a snapshot of results, and upload it to us using the attachment icon (shaped like a papaerclip) in the reply forms
    ken
  5. Posts : 27
    I can't as i am using my Macbook to use the internet as i can't get any from my PC desktop i restarted now and it wont pick it up anymore.
    If i uninstall all the drivers etc, is there anyway you can tell me how to install it properly so it will work with windows 7?
  6. Posts : 28,845
    Marc
    It might have helped for you to tell u s it is on a macbook. let us know when you can reboot to try to fis it
    ken
  7. Posts : 27
    I am on my Macbook talking on the forum, next to my PC which i am having the problems with... as i can't use the PC to use this forum as i can't get internet on it, but the stuff your saying and suggesting i am doing as the PC with Windows 7 on is next to me.
  8. Posts : 28,845
    IB
    so we are waiting on the snip of ipconfig
    ken
  9. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    I use Belkin N wireless adapter when on the road and my internal WiFi adapter don't find the signal; Belkin sometimes shows full signal quality when the internal shows only one or two bars out of five.
    Anyway, I got it to work only after uninstalling Belkin's own drivers and installing Windows generic wireless driver. After that it's been working perfectly.
    Kari
  10. Posts : 27
    where do i get the windows generic wireless driver from?
