Ok i installed windows 7 few days back the RC and i tried to install the Belkin USB Wireless adapter drive, now its installed and i restarted my computer now after restart and login it will connect to the internet for like 2-5mins and then disconnect when i try fix it totally looses connection and there no way getting it back unless i restart it again.
I find it strange how it works for few mins and just doesn't work at all and tottaly loses connection, anyone have any ideas why it isn't working?
Thank you,
Regards,
Mark
Thank you,
Regards,
Mark
Windows 7 Ultimate x64AMD Phenom(tm) 8750 Triple-Core Processor 2.4...4.00 GB
- HP
- Windows 7 Ultimate x64
- AMD Phenom(tm) 8750 Triple-Core Processor 2.40 GHz
- 4.00 GB
- Monitor(s) Displays
- 22" Samsung LCD
- Screen Resolution
- 1680 x 1050
- Hard Drives
- 500GB
1T External
- Internet Speed
- Virgin 20mps
