Windows 7: the problem of lap battery that loses chargeability
24 Nov 2012   #1
techno di
windows 7 64 bit home premium
one of the main advantages of LAPTOP over PC is the portability . this portability is attained by getting rid of the constant wall socket AC power through a 'Battery' ...
batteries are not forever-working components but a lifetime limited component .
my problem is that my new laptop battery lost chargeability after less than a year !
i bought a new one and it also lost chargeability .. long time back till now i use my laptop on the AC mains ...
is there any danger in using the device in the ac mains ?
what causes the battery to this problem ?
24 Nov 2012   #2
marsmimar
It will not cause any problems to run your laptop on AC all the time. I would suggest you remove the battery. This will prevent the battery from overcharging, overheating, etc and causing possible damage to the laptop.
As to why the battery won't hold a charge, it's hard to say. There are several variables involved. For example, just because you owned the battery for less than a year doesn't mean the battery was manufactured a year ago. It could have been sitting on a shelf in a warehouse for several years before you bought it. It could have been exposed to temperature extremes while in the warehouse. These two things alone could affect how well the battery holds a charge.
You also didn't say if the battery is nickel-cadmium (nicad or NiCd), nickel-metal-hydride (NiMH), or lithium-ion (Li-Ion). Each battery has different charging requirements so as to prevent building up a "memory effect". Most notable in Nicd batteries, the battery is not allowed to drain fully before recharging. Eventually the battery will not hold a full charge.
There is a website called Battery University that has a lot more info about batteries.
Basic to Advanced Battery Information from Battery University
24 Nov 2012   #3
techno di
thank u ....
i dont know about type of battery but i do think its (Li-Ion) ..
yes , am interested in hearing this , we costumers and non-professional buyers dont know about this and may dont think about ....
one note , the first battery of mine was the laptop's battery itself .. not a replaced one .
that one had been spoilt less than a year after !
i think there is a difference b/w laptops original - at the time of purchase- battery and the replacement battery
Internet loses connectivity, problem access point/ wireless adapter
So my computer has been having problems lately. I know it's only related to my computer, because my phone and my PS3 (which I added to the network AFTER the issues started) both have no issues running the internet. However, on my laptop, an Asus G73JH with a Qualcomm Atheros AR9285 Wireless...
Network & Sharing
Battery Problem - Consider replacing your battery
Last night when i switched on my laptop i was welcomed by a red cross on my battery icon which says consider your replacing battery :( I bought the laptop a year ago ,actually 13 months ago but i don't think it is the time to change my battery ! What can i do ?? Can i use my this battery for a...
Hardware & Devices
Cursor/mouse problem; loses window focus and jumps around screen
Hi, I've only recently begun having problems a few days ago with my cursor/mouse where the cursor will sometimes lose focus of the currently active window or the explorer bar (and I have to ctrl+alt+del to gain the focus back because clicking doesn't work). The same thing happens with flash based...
General Discussion
Battery problem
I replaced my dell battery. All volts ect were exactly the same. Worked fine for a month or so. Now the indicator says bat has 100% charge (if I remove bat the indicator says “no battery, reinstall and says 100% charge) but when I remove power cord computer does not work on battery.
Hardware & Devices
New Battery Problem
Hi All, Recently the battery in my wife's laptop died (full charge would last about 15-30 min at best), so we replaced it. The problem is that Windows 7 still thinks the battery is dead, and immediately pops up a warning when the computer boots saying basically "warning, your battery has 4 hours...
Hardware & Devices
Battery Problem
Since I installed Windows 7 RC1 on my PC, I started having a problem related with my Sony Vaio VGN-FE41S battery. When I insert it, my computer displays an error saying that the battery is incompatible and the computer will hibernate because of that. Any solution?
Hardware & Devices
