Overheated cabinet, thinking of using my stand fan... crazy idea?
xfact2matty
5:43 AM
Valhalla
I have a core 2 duo quadcore Intel CPU with 3ghz, a nvidia 1gb gpu with heatsink only..
I have only one processor fan installed, for months i faced overheating issue and decided to keep the chassis left open, for a month it was good now due to dust build up i believe the system is overheating immensely..
I have a big standfan with diameter larger then the cabinet which is not in use anymore...
if i place it in front of the motherboard would it cool the whole thing?
the fan has tremendous speed so i have to place it to appropriate distance so it does not harm the hardware.
What do you think?
Windows 7 Ultimate 32bitIntel core 2 duo 3 ghz2 GBASUS Nvidia 210 1 GB DDR3
Lenovo
Asus
2 GB
default
1366X768
Seagate 80 GB
Lenovo
1 processor fan
PS/2
USB optical
512mbps
It may help, but it isn't a fix. You need to clean your PC, probably put new thermal paste, and likely replace the CPU cooler with something better. A CPU overheating means way higher then normal temps, and will shorten the life to say the least. A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
It could help providing it doesn't stir up even more dust. Sometimes raising the case off the floor or desk by an inch or two allows for better air circulation. This article gives some more suggestions.
11 Ways to Keep Your PC Cool
Sony Vaio VPCEB47GM Laptop
Win 7 Pro 64-bit
Intel i5 2.4 Ghz
8GB DDR3
Intel HD 3000
IDT High Definition
15.6 WGXA Anti-Glare LED
1280x800
640Gb 7200rpm
