Hard Drive "Not Initialized", "device is not ready",won't recognize
Industrial Log
10:26 PM
I used a DriveWire - Universal Hard Drive Adapter (IDE / PATA / SATA to USB HDD Adapter) to hook up A 3.5" Hard Drive (Samsung model HD502HJ) to my desktop in an attempt to get my wife's files off her old desktop machine and merge them into mine. It all started off fine, the drive was recognized and I could see the files when I plugged in the USB cord. I started a NOD32 scan of the drive and a few minutes later a spark flew off my power strip and the fuse blew - looks like a letter opener shorted between two of the plugs. I think I killed the hard drive.
I replaced the power strip and started everything back up. The drive spins, but no longer is recognized by the computer when plugged in (no drive letter for it). Under Disk Management, I see the disk listed as "unknown" and "not initialized". Originally I had the option to right click and select "Initialize", and I was given option to use two partitiion styles (MBR or GPT).. I tried both to no avail, and get the "device is not ready" message.
I can right click select "Offline", and get the same message. right-click "Properties" say the device is working properly.
I plugged in another drive on the hard drive adapter and it works (so it's not the vault of the adapter). I try the same setup on my laptop and get the same results.
So I'm pretty sure I killed the drive. I just care about getting pictures and documents off it. Any advise? I know there are data recovery services out there that can probably help me, but I'd rather not pay the big bucks if I can avoid that.
Windows 7 Professional x64Intel(R) Core(TM)2 Duo4GBNVIDIA GeForce 8800 GT
Gigabyte P35-DS3L
4GB
on board
Acer AL2216W
ST31000333AS
ST750LX003-1AC154
HD502HJ
If you have killed the drive, there isn't very much you do about it. Even experts cannot sometimes recover anything, and it's just a wast of money.
Dual-boot: Windows 7 HP 32-bit SP1 & Windows ...AMD Phenom X4 9550 2.8Ghz4.0GB RAM256MB On-board ATI Radeon X1200 Series
Advent
Dual-boot: Windows 7 HP 32-bit SP1 & Windows XP Pro 32-bit SP2.
FOXCONN A6VMX (Socket 940)
4.0GB RAM
UnKnown
19" TFT Mointor
1400 by 900
500GB Western Digital WDC
HP Keyboard
Dial-up via Mobile phone (Three)
80GB External Hard-drive.
Also I have an old Windows XP Laptop for backup/occasional use etc.
You could try hooking up the hard drive (Google says the HD502HJ is a SATA drive) directly to your PC on one of the internal SATA connectors and a spare SATA power connector from your power supply. This will eliminate the adapter from the equation and simplify the test.
If the drive is recognized by Windows you just want to give it a drive letter. Initializing the drive could cause a loss of data.
If the drive is not recognized by Windows you could:
  • Run the hard drive manufacturer's diagnostic program on the drive
  • Run Windows Chkdsk on the drive
  • Use a third party program like Partition Wizard (using the self-booting CD from ISO) to see if you can give the drive a drive letter from outside of Windows.
By the time you are done with that you will know if the drive is recoverable or not.
If not, and while it is still hooked up to your PC, you can run a program like RECUVA to see if you can salvage the data from the drive.
Good luck.
Home Built - Jan 2013
i7-3820
Asus P9X79-PRO - Bios 4608
GSkill F3-14900CL9Q - 16GB
On board Realtek ALC898
Acer S271HL
#1- Samsung 840 Pro Series
Corsair Obsidian 550D
MS KC-0405
Intellimouse 5-button
56 Mbits/Sec (on a good day)
Avast & Malwarebytes
Asus DVD - DRW-24B1ST 24X
Adding to what TVeblen has said, if after a direct installation on the PC, the drive does not show up in BIOS, it is as good as beyond redemption, IMO.
But considering the nature of the accident that happened, the precipitating factor in the drive becoming unreadable seems to be the sudden termination of a running program (though a possibly large transient could have also killed the electronics.). I shall give it a fair chance of recovery.
Let us see how the drive looks in Windows Disk Management.
Windows 7 Home Premium 32 bit
Thanks for all the advise.. that gives me a bunch of things to try, I will try some of this tonight and see how it goes. Fingers crossed.
Gigabyte P35-DS3L
4GB
on board
Acer AL2216W
ST31000333AS
ST750LX003-1AC154
HD502HJ
Update
Here's what I tried:
- Checked BIOS (does not recognize drive)
- Downloaded the Seagate "Seatools" harddrive diagnostic program, both Windows and DOS versions, tried both without success.
- Tried "MiniTool Partition Wizard", did not see the drive
- Tried "MiniTool Power Data Recovery" (free edition), did not see the drive.
- Tried "RECUVA", didn't see the drive.
- In Disk Management when hooked up directly to the motherboard via SATA cable, it lists it as "Disk 2", "Removable" and allows me to designate a drive letter, and change drive letter.. but the drive won't show up. When I type the drive letter ("N:\") in Windows Explorer, it says "Please insert a disk into Removable Disk (N:)"
So it's not looking good. If anybody has other ideas, perhaps data recovery software to try out, please let me know. And thanks for the advise so far, I appreciate it.
Gigabyte P35-DS3L
4GB
on board
Acer AL2216W
ST31000333AS
ST750LX003-1AC154
HD502HJ
The system thinks it's a DVD or Zip drive. Interesting.
What's confusing is the fact that Disk Management can see the drive but PW or Seagate can't? And this is with the drive connected internally?
If you can get PW to see the drive you could try this to rebuild the MBR - using the bootable CD:
How to Rebuild MBR with partition manager - Partition Wizard Rebuild MBR Help
But my guess at this point is that the drive is electrically alive but the controller is shot, so the system sees a drive of some sort but can't read anything on it.
If you can't get it recognized and you need to recover files there is the possibility of switching out the control board, but that is a long shot.
i7-3820
Acer S271HL
MS KC-0405
Yes, all these steps were done with the drive hooked up internally. Since I can't get Partition Wizard to see the drive, I'm doubting the rebuilding of the MBR would work, but I'll give it a try.
Gigabyte P35-DS3L
4GB
on board
Acer AL2216W
ST31000333AS
ST750LX003-1AC154
HD502HJ
The "N" drive it is seeing might be a memory card slot or card reader somewhere on your system.
I have had good luck testing HD's with HD dock units ;)
on motherboard
6 pata Ide HD's & 2 Sata HD's
All Generic Full Towers
Fast Cable InterNet
Linked via TeamViewer !
DocBrown-
You're right, when I go into properties it's identifying it as my printer - I guess nothing is seeing this drive.
Gigabyte P35-DS3L
4GB
on board
Acer AL2216W
ST31000333AS
ST750LX003-1AC154
HD502HJ
Another shot in the dark would be to try reading the drive with another computer.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
......- In Disk Management when hooked up directly to the motherboard via SATA cable, it lists it as "Disk 2", "Removable" and allows me to designate a drive letter, and change drive letter.. but the drive won't show up. When I type the drive letter ("N:\") in Windows Explorer, it says "Please insert a disk into Removable Disk (N:)"
Since Disk Management still shows it as drive albeit as a removable disk, I would think that you should give TestDisk a shot.
http://www.sevenforums.com/software/190430-regain-lost-drive-using-test-disk-illustrated-guide.html
http://www.sevenforums.com/software...ive-turned-raw-partition-wizard-testdisk.html
Yep, we are shooting in the dark. Let us, in all directions.:)
Well, my story has a happy ending. I brought my dead harddrive into work and let my electrical engineer have a go at it, he has a similar cable to my Drivewire.. he hooked it up to his laptop running Windows 8 and it immediately recognized it (using USB3). We copied the files over and left the drive alone so I could try his cable at home using the drive to see if it worked. It works (via the USB on the new cable setup) on my desktop.
Next I tried my original cable setup (to make this a USB drive), and that works now as well. Somehow I think Windows 8 got through whatever was blocking it and unfroze it. Or I just got lucky.
Gigabyte P35-DS3L
4GB
on board
Acer AL2216W
ST31000333AS
ST750LX003-1AC154
HD502HJ
Good to know that. And yep, I do remember having come across such an incident. So I think we should ask OPs to try on a Windows 8 machine as a first step.:)
