Microphone not working. Audio Device Error.
Hi.
I bought the Editors Keys Studio Series SL300 Microphone. The Mic is supposed to have all of the required drivers already installed inside of it so that when you plug it into the computer it will be ready to go (it's a USB Mic btw). The problem is when I plug the mic in, it says that the USB Audio Device is not working properly. When I look under the properties for that device it says: Device Status-This device cannot start. (Code 10). I've tried troubleshooting the device and everything but nothing is working. All of the other devices installed in the mic are working properly, just not this one. Since it won't work properly the mic does not even get detected by my laptop, it doesn't show up under detected recording devices.
In case it helps, my computer is an Acer Aspire V3-571
I think I tried everything.
-I did troubleshooting.
-I reset my computer back to factory defaults, so I don't have previously installed drivers conflicting with this one.
-I've reset my computer multiple times and reinstalled the mic multiple times.
If anyone has an ideas it would be great, Thanks!
