Windows 7: Using a 6pin and half of a 4pin for 8pin CPU power on new mobo?
30 Dec 2012   #11
bobkn
Windows 7 Pro X64 SP1
That's strange.
As you probably already know: here's a link to an image of an 8 pin ATX 12V male connector:
http://www.nordichardware.com/skrive.../psu.8-pin.jpg
Each 4 pin side of the connector should have two D shaped pins and two square ones. On your CM unit, one side is all D shaped. Looks like the unit was somehow made wrong.
(The only other 4 pin connector that resembles the ATX 12V one is the 4 pin block from the ATX 20+4 pin one. However, it also has two D's and two squares, and it has no locking clip.)
I suggest that you share your pictures with Cooler Master support (www.coolermaster.com). It would be interesting to see what they have to say about your situation.
30 Dec 2012   #12
XGamer95
Windows 7 Ultimate 64-bit
Quote   Quote: Originally Posted by bobkn View Post
That's strange.
Yes, this is why I thought the connector wouldn't work but it turns out it does . The D pins will fit in the square holes so I am currently using my new build. About the CPU fan, it's power cable was too tight around it and the fan was hitting it as it tried to spin, stopping it all together. Thanks everyone for all your help.
New Mobo only allowing half of my Ram?
Good morning everyone, recently i bought a new mobo and CPU. now that everything is installed its telling me i have 16GB of ram installed, but only 8GB are usable.... http://i592.photobucket.com/albums/tt7/Renzokucant/ramproblem.png here is my new processor, which i dont think applies to this...
Hardware & Devices
PCI-E 6pin power Bodge
Okay so my new GPU needed the 6 pin , i forgot where i put the adapter ! it was late ! i had 5 strongbows ! i was crazy ! I cut the 4 pin atx power of and cut another of two broke psu's Cut one in half and put them in the 6 pin power slot on the card 3 tops where ground 3 bottoms...
Chillout Room
4pin of a 20+4 pin mobo power was n0t plugged in. What happens?
Hello, i have some simple questions. My system randomly turns off. no blue screen. No crash dump. no windows shutdown screen. This isnt really about the shutdowns. 1 - What happens when the 4pin connector of a 20+4 pin mobo power plug is disconnected 2 - Does the 4pin connector give more...
Hardware & Devices
Can I connect a graphics card with 6pin power connector, to a 4pin?
As the topic implies, can I use a 6-pin graphic card when I only have 4 pins on my motherboard? I want to upgrade to a gtx 550 ti, and my motherboard is Asus P5KPL AM-SE. Can I use this card? P.S. Sorry, I am still a noob at computers.;3
Graphic Cards
Targus recalls half a million laptop power adapters due
Targus recalls half a million laptop power adapters due to burn hazard Source: Targus Recalls Half a Million Laptop Power Adapters | Technibble Comarco Adapter Recall If you have any adapter matching the SKUs listed, contact Targus immediately. ~Lordbob
Chillout Room
Mobo/CPU power cable ?
I have a ASUS P6T mobo with a i7-950 CPU.The mobo has a 8 pin power cable connection for the CPU, but 4 of the pics are covers. Not 4 on one side, but 4 on one end. I have the machine running, all is well, but I'm wondering if I should get an 8 pin cable and use that instead of the 4. I don't do...
Installation & Setup
