Laptop Fan Problem - Too Low - How to Increase
bjj8383
6:35 PM
Note: Best Buy fixed the issue a while back. I had to reformat since then, and my service plan is up. So I'd like to re-fix it myself.
This is the original problem: I'd had my computer (Asus notebook G73jh) for 6 months. Suddenly out of the blue, I couldn't play any game for more than 10 minutes without my computer overheating and crashing. Best Buy, quote, "updated the BIOS" in order to "fix the fan speed" and it seemed to do the trick.
So, fast-forward. Reformat. Start experiencing the same problem again. Update the BIOS version myself. ... Still happening.
If everything that I think is true IS true, then, I just need to do something with the fan speed. I can't find how to increase it. Everything I read on the internet tells me that my fan speed should already be maximized, which is why there is no BIOS option where you can tinker with it; the only thing I can find on the internet is people asking how to LOWER and quiet their fans. That is the opposite of what I need. I want to crank the sucker so I can actually play my games again. If you can tell me how, please do so. Thanks.
Windows 7 Home Premium 64 bitIntel Core i7 Q720 1.60GHz8 GBATI Mobility Radeon™ HD 5800
Asus G73Jh
8 GB
Reformatting your computer wouldn't change the bios update. I have an Asus motherboard in my PC and there is a program called AI Suite II that can be installed from the driver DVD, or downloaded and installed from the Asus website. AI Suite has a section called Fan Expert where you can adjust the CPU fan speed.
Windows 7 Home Premium 64bit SP 1Intel i5 2500k8 gigabytes Corsair PC3-12800 DDR3EVGA GeForce GTX 460 superclocked
Customized build from CyberPower
Intel i5 2500k
Asus P8P67 Deluxe
ViewSonic 23" LCD
1980 x 1080
120 Gb Samsung 840 Pro SSD
120 Gb Kingston Hyper X SSD
1 Tb WD Caviar Black HDD
Coolermaster 1000 watt modular
Coolermaster HAF X full tower
Coolermaster Hyper 212 plus
Logitech USB
Microsoft 3 button
download 1.5 Mb/sec upload 300Kb/sec
One thing I do on every older laptop I work on is to carefully remove the back cover and use compressed air to clean off everything, especially the cooling fins near the fan and heatpipe. I also remove the heatsink form the CPU/GPU and clean the CPU and GPU to remove the old thermal compound and clean the old compound from the heatsink and I apply a small amount of Arctic Silver compound and then reattach the heatsink to the CPU/GPU. (I'm not affiliated with the company, just a satisfied customer) and the temps almost always drop after doing this. Just be very careful and don't force anything!
Microsoft Windows 8.1 Enterprise 64-bitIntel(R) Core(TM) i7-3770K CPU @ 4.7GHz (Over...32 GB 12800 DDR3 Crucial Ballistix SportNVIDIA GeForce GTX 660 SC x 2 (SLI) by EVGA
Intel DZ77GA-70K
Intel(R) Core(TM) i7-3770K CPU @ 4.7GHz (Overclocked)
Intel Corporation DZ77GA-70K, 0066 BIOS version
(1) Bluetooth Hands-free Audio (2) NVIDIA High Definition
LG 27" HDMI
12920 x 1080 x 32 bits (4294967296 colors) @ 60Hz
Intel 120GB SSD (ATA INTEL SSDSC2CT12 SCSI Disk Device)
Western Digital Caviar Black 64M cache 2TB 7200rpm (ATA WDC WD2002FAEX-0 SCSI Disk Device), 3 x WD 150Gb 10k Velociraptor hard drives in RAID 0 (testing)
Corsair 750w fully modular
Corsair 650D with perforated side panel
3 200mm case fans, Intel liquid cooling for CPU w 120mm fans
Logitech backlit
11Mbps DSL
Windows Defender, MalWareBytes Pro and CCleaner Pro
Chrome, IE and FireFox (latest versions)
Windows Home Server 2011 with 10 clients at home
