Windows 7: between low-end e-ips and normal led monitor?
20 Feb 2013   #1
rovopio
windows 7 home premium 64bit
dear sevenforums user...
im looking for a new 22" monitor to be my second monitor on my laptop. the primary usage is for watching 720p videos and a bit of reading pdfs and docs as well.
i have a limited budget of $150~$220.. from the monitor products they sell in my country, i could get low-end e-ips model like asus ml229h or aoc i2352vh for exactly $220.
on the opposite end, there are 22" TN monitor that i could get like $160 samsung and AOC $150 e2250swd..
since im not really good with IT... i wanna ask you all.. with that budget, does the low-end E-IPS trumps pricy TN monitor, picture quality wise..?
-ended up with dell e-IPS panel-
21 Feb 2013   #2
ICIT2LOL
Hello again KP well personally I would go 24" with either this BenQ GL2450HM ($169) here or this
BenQ RL2450H ($199) here. I don't know how prices compare between there and down here but surely it could not be a lot.
That is if you have the space to put it - the difference between the 22" and the 24" is a no brainer.
The BenQ's I like best too just a quality product
But if it has to be a 22" then this is good Dell S2240L ($149) here
22 Feb 2013   #3
rovopio
Quote   Quote: Originally Posted by ICit2lol View Post
hey i see it 2 lol~
they sell different products here~... you know... inferior models for 3rd world country market thingy lol
anw... yeah.., so i still couldn't follow your reply... so is it better to get lower end E-IPS panel.. or should i stick with TN monitors...? provided that both cost around the same $180-$220ish
ps:the benq rl2450H cost $370 here... odd pricing huh
22 Feb 2013   #4
ICIT2LOL
Hum that is some heck of a price difference from the little I know the TN have a faster response and the IPS a better colour quality so taking that as rough guide it really depends on what you plan to do with your machine in the future.
For what you are doing now personally I would go for the colour quality rather than the response time as for me it is a much of a muchness, and I myself would have a job picking the difference. Plus you did mention too you like picture quality too.
Out of the two you mentioned first up I would pick the AOC purely because it has good reviews like this AOC i2352Vh review | Monitors Reviews | TechRadar and it is just within your price range plus it is 23" - the clincher for me as 22" is ok for tester machines like I have here but for plain easy viewing the 23" just runs rings round the 22"
22 Feb 2013   #5
rovopio
hello~.. i initially wanted to get 19" monitor as i only wanted to use it from 15-25" distance multitasking (of course a bit farther when watching video)
but since IPS started with 22-23" (and way more options on the 23 than the 22), in your opinion with that kind of short distance... is it too big to get 23" compare to getting 22"
on my price range, there are AOC 2353 philips 239c4qhsb dell u2312hm asus ml229h and the cheapest of all is lg ips 225v
do you have any experience with looking at LG monitor, or any monitor brand you tend to lean to from those options?
thankss~
22 Feb 2013   #6
ICIT2LOL
No mate I haven't had nay experience with LG and I have seen many posts with problems on this brand. Out of the rest you have quoted the AOC , Philips, and the Dell are the pick of the bunch if they come within your price range.
I have had both Dell and Philips monitors and they are very good AOC I haven't but they always seem to get good reviews. But it is a shame about the BenQ as it is just brilliant.
As for sitting too close I use 24" monitors on three of my machines and I sit no more than 24-26" from them and I have to say I just couldn't use anything less sized now, I would find it irritating to be honest. If you are worried about the pixels being visible - don't it isn't an issue. Plus if you want to sit a little further away for videos then alls good and you can use a little longer hook up cable if need be
22 Feb 2013   #7
rovopio
oh that sounds good icit2lol...
btw, just curious... some brands like AOC and asus offers HDMI... so, i know that if i wanna use the monitor as a TV someday i could do that.
but dell u2312 only have dvi-d and display port... if i wanna use the monitor someday (not now) as a cable TV... is it possible to do so with the HDMI to DVI cable,, and.. how about the sound? just put external speaker on the microphone jack or smthn....?
22 Feb 2013   #8
ICIT2LOL
Quote   Quote: Originally Posted by kungfupanda7 View Post
Sorry for late reply mate am on night shift at the moment.
In a nutshell KP the HDMI carries both graphics and audio signals and the DVI graphics signal only so you would need to set up the sound separately if you use a DVI link up.
In my mind there is no appreciable difference in the graphics quality between HDMI and DVI the latter I use myself because I have dedicated sound cards in all my machines for sound / audio.
So to answer the question you need to use the HDMI hook up should you need the monitor to operate as a TV from say a video recorder / player or from the laptop.
If you get the one that has both types of connection then you have the choice to use the monitor as required, but get the best that you can the cheaper brands are in my view inferior in every way
I meant to add too that I use DVI also because the HDMI connections are prone to easily dislodging.
23 Feb 2013   #9
rovopio
due to odd pricing here... im gonna go with dell u2312 will come back after i get it on monday...
btw.. just curious,, which one is your preferred brand of storage between 3.5" WD mybook essential vs seagate freeagent go flex desk, or do you go with other brands...?
im using WD mybook external 3.5 at the moment but i read amazon reviews regarding the flimsy socket and im thinking of probably buying another storage along with buying the monitor... kinda wondering other people opinion regarding their preferred brands of storage
23 Feb 2013   #10
ICIT2LOL
Hum nice choice on the Dell from what I hear they are real good.
The drives I always go Seagate I tried the Go Flex but apart from being detachable not that much advantage over a normal "straight" drive, mind you I only had the 500GB small one the larger ones may be better.
Can I format my PC from Safe Mode? Monitor blank if I normal boot...
When my PC worked fine I would get a graphics driver error but Win 7 would recover from it and I would continue as normal. Now when I boot, my monitor recieves "no signal" from the PC. The PC boots fine except I cannot see anything. This means that I cannot format my PC because I can't see what...
Installation & Setup
Laptop monitor dilema. Is it the monitor or the intigrated video card.
I didn't know if I should have put this in the general discussion page or the video card page but here it is. :D My laptop has been acting up today. I would open the lid and it would have strange colors. For example blues would be a strange red color. But it would automatically fix itself and...
Graphic Cards
Radeon HD 6670 Dual Monitor setup not detecting 2nd monitor
I am having troubles getting my dual monitors back. Initially had a GeForce 8400GS 512MB PCI video card and was using the on board video (Biostar G41 M7 MB) for dual VGA monitor setup. I've installed a Radeon HD 6670 1GB PCI-E video card with monitor one setup via DVI to VGA adapter on output...
Graphic Cards
Can a normal LCD Monitor be used as a Pen Tablet?
In my Windows 7 Professional's control panel I found a tool called "Tablet PC Settings." I opened it to see what it was. It reports that my HP w1907, which up to now I though was just a regular lcd monitor, can accept pen input. If this is true and not some software glitch by the os, what...
Drivers
[Monitor] Is this normal?
Hello, I get some horizon lines sometimes on one of my screens, they ain't coloured, just gray and dark. I have two screens, the one which is doing it, is running 1680x1050. The lines hang in 0.5-1sec only. My GPU is around 49-57 celsius. When I move my monitor, the lines it also appearing, and...
Hardware & Devices
Is DVI better then the normal monitor cable?
i was always wondering if i should get a DVI cable. what are the pro's and cons of it? Is it producing better Video Quality?
Graphic Cards
