Windows 7: Samsung 27" LED SyncMaster S27B350H Calibration Help!
26 Feb 2013   #11
Petey7
I'm glad you were able to get it and I hope you enjoy your setup. A word of warning, once you get used to two screens, you'll never want to go back.
26 Feb 2013   #12
boohbah
Quote   Quote: Originally Posted by Speluncus View Post
Thanks for the answers
I have already tried the options in the control-panel, although I actually found a fix!
The monitor had a "Sharpness" option, which I had overlooked when I calibrated the monitor.
The slider was on 100/100, I pulled it down to around 50. It solved the pixelation which I mentioned in post #5 and #6. (Sorry for posting several posts! New to forums, still haven't learned to use all of the features.. )
But this solved everything for me, so thanks again!
Best forum in the world so far
good news, just a tip if you need to post any pics in future...
Computer Requirements for Samsung 27" LED SyncMaster S27B350H
Hi Guys, So I am thinking of upgrading from a Samsung 22" SyncMaster 226BW to a Samsung 27" LED SyncMaster S27B350H. However my Tower is an old 5 -6 yr old one with an -Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz (2 CPUs), ~2.1GHz -ASUS P5AD2-E motherboard, -NVIDIA GeForce 7900GS ...
Hardware & Devices
Samsung Syncmaster 950p Plus / Windows7
Hey Folks Can't get my Samsung Syncmaster 950p Plus running properly under Windows 7 64 bit and a Radeon HD 5770 card. Any help or links to downloads?? heeelp!!!! :)
Drivers
Samsung Syncmaster 193V Problem
Everytime i google this driver and even when i download it of samsungs website it downloads a bing maps 3d installer by microsoft this is baffling me does any one have any suggestions or even a link to the correct driver many thanks
Drivers
driver for samsung syncmaster 959nf
I have the samsung syncmaster 959nf and can not find drivers for windows 7 64bit to put it in the sreen refrash rate 100Hz and has only 75 and 85
Drivers
Samsung syncmaster 2333hd drivers ?
pls HELP recently instaled wista 7 32 bit home premium but does not work with sync mast 2333hd enybody knows is there any drivers or infos about this... tks in advance
Drivers
Samsung Syncmaster 933SN and native resolution
My monitor: Samsung Syncmaster 933SN won't display at it's native resolution which is 1360 x 768. It will only display at 1024 x 768 which only takes up 2/3rd's of the screen real estate! I have the most updated driver for the monitor, 3.0.0.0 from Samsung, which says it works on XP, and VISTA...
Graphic Cards
