Windows 7: Noise issue on startup - possible fan issue?
26 Feb 2013   #1
scamander
Windows 7 Home Premium 64 bit
Hi all,
Got my new PC mid Jan so wasn't expecting any issues. However in the last week startup has become a noisy process. The best description is of a grind/rattle which only lasts a few minutes and then settles down.
I suspect it's an issue with a fan, though which one I am not sure. Dust/wires has been voiced as a possible but I've only had the machine a month and a bit.
It's under warranty so I've got the option of sending it back to be looked at, this involves collection/delivery and would see me PC-less for at least a week. I spoke to the firm I bought the machine from and they suggested opening it up and seeing if there was a snagged wire or dust issue. I'm just a bit concerned about trying to solve it this way as though I played around with my old PC I really don't want to open this one up unnecessarily. There's also the fact that it might be something more serious, perhaps a fan issue (I've read something about ballbearings).
Anyway - thoughts and advice welcome as ever.
cheers
26 Feb 2013   #2
Layback Bear
Windows 7 Pro. 64/SP-1
If you have proof and only if you have proof that the company authorized opening the computer would I suggest opening the computer.
Have them send you a email which would be proof. If you don't have proof I would send it back for them to inspect. It will take time and trouble on your part but you don't want to loose the warranty.
26 Feb 2013   #3
scamander
that's a very good point - think I'm going to take the non-easy option and let them handle it. Cheers!
28 Feb 2013   #4
scamander
just as an update (and perhaps a pointer for anyone else who has had similar). I got an email back from the company allowing me to open the case up to identify which fan.
Opened it up and booted up - no noise, put the case back on, no noise. After work the boot-up saw the noise return and I was able to work out that it's the fan in the front of the case. Well, it actually seems to be the case itself as putting your hand on the top of the front of the case or anywhere near stops the noise. Must be a loose fitting perhaps.
Either way it's not the fan for the graphics card, PSU or CPU so I'm very glad. Going to leave it be as it isn't vital.
28 Feb 2013   #5
kbrady1979
If it is only at startup, it could be that the fan is out of balance or not mounted properly and the high rpm of the fan is messing with the harmonics of the case. It could also be mounted just fine and mess with the harmonics of the case. Make sure the fans are snug in the housing and make sure the case panels aren't loose. Does it ever make that noise after the pc has been up and running for awhile, or is it ONLY on startup?
Startup issue
Any idea why since I discovered that my monitor with a 1280 x 768 resolution looks way better, problem is when I reboot the computer the image is over scanned so much the taskbar is completely gone. I have to set it to 1024 x 768 (bad picture) and back to 1280 x 768 and I have a perfect desktop. If...
Graphic Cards
startup issue
hey people i had some issues regarding my windows startup problem.. i tried to fix it with a bootable usb drive with the version of windows i'm using and it worked for sometime but after i started to install the drivers and restarted my laptop it started to give the problem again.. is it because...
General Discussion
Please Help, Windows 7 Startup issue
I'm having a problem with my Laptop. It runs on Windows 7 Home Premium 64 bit, it is a Dell Inspiron 1545. Everytime I start up my computer, it goes to the black screen with the choices "Start using Windows Start Up Repair" or "STart Windows Normally". If I start windows normally, it does a quick...
General Discussion
Gigabyte GA-X58-UD3R (Rev. 2) - Realtek ALC889 Static and Noise Issue
Problem: I am having issues with the on-board audio, where there is intermittent static, that seems to be only present while playing any audio while in Windows - event sounds or WMP, but disappears when using other applications either gaming, or streaming video, like YouTube. As an observation it...
Same startup message issue
Hello, I'm back again with the same issue that was resolved before, but a system restore did not work this time. I installed Microsoft XBox 360 Accessories app from Microsoft to use my 360 controller on my PC. The install went fine and the controller worked. When I started my PC this...
Hardware & Devices
Startup Repair issue?
Here is the story, a computer got a virus, and was beyond repair, So we went for a clean format. The computer was for some reason unable to boot from the windows disk, or any disk for that matter. So i hooked up the hard drive to another motherboard, and installed windows 7 from there. And hooked...
Installation & Setup
