Windows 7: need help with strange (glitch?) with sound randomly not working
05 Mar 2013   #11
fireberd
Can you break it down to just one function? e.g. not have Skype, YouTube, Recording DAW software, etc., all going at the same time and all vying for the sound device. Too many devices at one time and if one of the applications does not release the sound device then it would act like you are seeing.
If one application you try does not cause the problem, try another (just the one application) and see if it does it with that.
If any application will cause it, there could be a Windows corruption for the sound. Uninstalling the device (IDT) in the Device Manager (but NOT the drivers) then restarting the PC will force Windows to reinstall the sound and many times fix flakey problems.
05 Mar 2013   #12
Diddy7Kong
Windows 7 Professional 64 bit
happens with ALL programs, and i need skype and a recorder going at once, because i dont feel like having two computers just to record a skype call in clean quality and this is my first computer to do that, everything else i used to have never had this and could have 75 things using the sound at once
05 Mar 2013   #13
indianacarnie
Hate jumping in late on these posts, but have you ran an sfc/scannow to check for corrupted system files?
Also, have you been here and tried any of their solutions?
Microsoft Fix it Solution Center: troubleshooting software issues
06 Mar 2013   #14
fireberd
What do you use with Skype? A standard analog PC headset (plugs into the mic and headphone jacks) or a USB type? If you are using a USB type usually they will change the default playback to the USB headset. On Recording, unless you have the Stereo Mix (could be called System Mixer) set as the default recording device that could also be causing some conflicts and problems.
I personally don't like the Microsoft "fixit". Its never fixed anything for me.
Sound on Laptop and Desktop Randomly Stops Working and Working
So recently the sound on my desktop and my laptop has stopped working. For seemingly no reason. I really don't understand it. I first noticed it with my desktop. The sound just randomly stopped working. But not...entirely. It's really strange and complicated what's been happening, so bare with...
Sound stops working randomly after a while
Hi I've bought a set of new speakers for listening to music on my PC. However they stop playing randomly after a while. If I then go to the Device-manager and rightclick on the speakers (which is set as the default Device for sound) and do the test it works again for a while, whereupon the pattern...
Hi, My acer (aspier v5 171 Series) (windows 8) has been working smoothly for 1 year now, but since couple of days the sound would go off if something is not being played for sometime. then I need to restart to get it back...initially I though it happens after I lock the laptop but today it went...
HDMI sound randomly stopped working
sorry for starting a new thread but i have searched through so many and still not found a fix for my issue I was watching a movie and sound worked perfectly fell asleep woke up the next morning and no sound through my tv connected via gainward gtx550ti HDMI port it still shows in playback...
HDMI Sound randomly not working - test in settings gets it working?
I have started having an issue over the past week (config/drivers/etc not changed in months) where sound will randomly not be output by HDMI. System config/specs... Win7 SP1 all patches, nearly a stock install... only running WMC and XBMC. Only 3rd part stuff installed are SpeedFan an ATI...
Strange glitch?..
When I view video content, not always, but most of the time I get this type of screen: http://i51.tinypic.com/11j4qo3.jpg Sometimes it's not like that exactly, like sometimes when something on the screen moves fast, remnants of where the image used to be are still there. Hard to explain.. It...
Graphic Cards
