A rather annoying reboot problem
So, I was just bringing my computer out of Sleep mode with my new ASRock motherboard and for some dumb reason not 60 seconds after it got back into Windows, it resets. No BSOD, no dump, no message saying that it "recovered from a serious problem", nothing!
I can tell you this though, the board in my System Specs features the Dehumidifier function, which, when activated in BIOS, allows the system to reduce moisture and prevent damage to critical components when the system is started from standby or hibernate, or even from cold boot. Should I go in there and Disable the Dehumidifier Function?
