Possible Hardware problem, error 3d
  1. Posts : 16
    Oops
    Arc said:
    The display driver is still not the latest WHQL.
    fffff880`07067000 fffff880`07b7d000   atikmdag T (no symbols)
        Loaded symbol image file: atikmdag.sys
        Image path: \SystemRoot\system32\DRIVERS\atikmdag.sys
        Image name: atikmdag.sys
        Timestamp:        Thu Dec 20 02:08:55 2012 (50D225DF)
        CheckSum:         00AC6529
        ImageSize:        00B16000
        Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
    Care to update it?
    The MSINFO32.nfo we wanted. You uploaded msinfo.exe. We need the .nfo file only, no exe. Coz, executing the .exe I will get "my" msinfo only, not your.
    Sorry about that arc, I guess I did not read the directions carefully. Here is the file you wanted. And I updated my drivers like you requested
    Possible Hardware problem, error 3d Attached Files
  2. Posts : 21,004
       #12
    Just as side issue bortelli if you want to find some RAM for that board try the G Skill forum - thats all Tradesman does - RAM related stuff.
    Welcome to the G.SKILL TECH FORUM
  3. Posts : 16
    Strange Network Problem
    About two days ago I realized that my icon that displays that I am connected to the internet says "Not connected - no connections are available". Yet I can go on the internet just fine. I've uninstalled and reinstaled my networks drivers, and I still displays the same message. Thats a little strange.
  4. Arc
       #14
    That might be bluetooth. Disable bluetooth in device manager and see if there is any change?
    Apparently your MSINFO32 is fine .... well managed computer I can see. Will check it again, by comparing any further crash dump. Did it crash in between after updating the driver?
  5. Posts : 16
       #15
    More Crashes
    Yes is did actually! Its a shame too. I got a lot of random errors from bad pool caller to paged aread to nonpages area.
    As a side note, I haven't activated windows yet, and wondering if that has anything to do with it.
  6. Arc
       #16
    Not exactly, but you should activate it. It is not a big hassle to activate windows.
    The possible problem is that you havent updated display driver yet, as I am seeing
    *** WARNING: Unable to verify timestamp for atikmdag.sys
    *** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
    *                        Bugcheck Analysis                                    *
    Use !analyze -v to get detailed debugging information.
    BugCheck A0000001, {5, 0, 0, 0}
    Probably caused by : atikmdag.sys ( atikmdag+2311c )
    Followup: MachineOwner
    3: kd> !analyze -v
    Unknown bugcheck code (a0000001)
    Unknown bugcheck description
    Arguments:
    Arg1: 0000000000000005
    Arg2: 0000000000000000
    Arg3: 0000000000000000
    Arg4: 0000000000000000
    Debugging Details:
    CUSTOMER_CRASH_COUNT:  1
    DEFAULT_BUCKET_ID:  WIN7_DRIVER_FAULT
    BUGCHECK_STR:  0xA0000001
    PROCESS_NAME:  System
    CURRENT_IRQL:  b
    TAG_NOT_DEFINED_c000000f:  FFFFF88001EFDFB0
    LAST_CONTROL_TRANSFER:  from fffff880074df11c to fffff80001adac40
    STACK_TEXT:
    fffff880`01ef6648 fffff880`074df11c : 00000000`a0000001 00000000`00000005 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
    fffff880`01ef6650 00000000`a0000001 : 00000000`00000005 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0x2311c
    fffff880`01ef6658 00000000`00000005 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`093618a8 : 0xa0000001
    fffff880`01ef6660 00000000`00000000 : 00000000`00000000 00000000`00000000 fffffa80`093618a8 fffff880`01ef66b0 : 0x5
    STACK_COMMAND:  kb
    FOLLOWUP_IP:
    atikmdag+2311c
    fffff880`074df11c ??              ???
    SYMBOL_STACK_INDEX:  1
    SYMBOL_NAME:  atikmdag+2311c
    FOLLOWUP_NAME:  MachineOwner
    MODULE_NAME: atikmdag
    IMAGE_NAME:  atikmdag.sys
    DEBUG_FLR_IMAGE_TIMESTAMP:  50d225df
    FAILURE_BUCKET_ID:  X64_0xA0000001_atikmdag+2311c
    3: kd> lmvm atikmdag
    start             end                 module name
    fffff880`074bc000 fffff880`07fd2000   atikmdag T (no symbols)
        CheckSum:         00AC6529
        ImageSize:        00B16000
    Stress test the Graphics Card using Furmark.
    Video Card - Stress Test with Furmark
    Is the computer hot? Report us the heat of the computer after a couple of hours of your normal usage. Upload a screenshot of the summery tab of Speccy.
    Check the power supply with eXtreme Power Supply Calculator
  7. Posts : 16
       #17
    When using furmark, my graphics card capped at around 64'c.
    I used The power supply tool you mentioned, I guess thats in case I need another one?
    And this Time I Did update my display driver, and I still crashed. Also I dont have any bluetooth enabled devices, and for some reason It stills says I am not connected to the internet.
    Here is the crash and speccy screenshot.
  8. Arc
       #18
    This crash also indicates to the display driver, despite of it being updated. So it is not the problem if the driver itself as far as I guess.
    Nothing is overheating as per speccy. And 64 degrees is not a high temp for a stress test at all. Have you noticed any artifacts or abnormalities during the Furmark test?
    About PSU, what's the result you got there? Is it supplying adequate power or less? If less, all the problems are possible.
    BTW, can you use the onboard graphics to observe is it failing there too or not?
  9. Posts : 16
       #19
    I know this thread is a little aged, but I finaly came across a permanent solution. After loading my Bios to fail-safe defaults, everything is ok.
  10. Posts : 19,383
       #20
    Good news - thanks for posting the solution.
