Windows 7: IBM 11a/b/g Wireless LAN Mini PCI Adapter II WPA2-PSK issue.
16 Mar 2013   #1
Prof Kerfuffle
Windows 7 Professional (x64/SP1) /Linux Mint 16
Hi there, I'm having an issue with my ever so brilliant IBM Thinkpad T42p, only it's not so brilliant at the moment as it has a wireless issue. WPA2-PSK is the standard for wireless security as I believe, my T42p was made in early 2005 and the adapter hasn't really been properly updated to support this security type. I have tried custom drivers to the latest drivers.
The latest drivers crash the OS for several minutes and fail to install, even when digitally signed and the custom drivers work a treat on WEP and other network security types not the modern standard though. Changing my wireless security type isn't an option, any ideas? Windows 7 works superb with the drivers but I prefer XP on this laptop as it can only handle so much and its aging. So I would need XP drivers on an quite frankly an ancient mini pci IBM Wireless card that supports modern WPA2-PSK.
If it's too much trouble I am just going to rip one out of my HP laptop but I prefer not to.
Again, any suggestions?
22 Mar 2013   #2
Prof Kerfuffle
No one?
Anyway, it worked on some routers and failed upon others so I decided to bite the bullet and swap the cards from my other laptop.
It works great now, its an Intel something... and connects properly due to better and updated drivers. Interestingly the Thinkpad has all its original parts and the bios reported the CPU, Intel Pentium M and now I have replaced the card it's made it a Centrino (Intel branded chipset groups, Wifi, cpu and whatnot).
For anyone who owns a thinkpad and wish to check the parts list visit ThinkWiki. It maybe for Linux but hardware wise it applies to any OS and does give info on Windows anyway
Qwest 11n wireless adapter driver issue
I just upgraded a friend's HP desktop from Vista to Win 7. The Qwest 11n wireless adapter (actually an Actiontec 802ain) which worked fine in Vista, now has a problem. Everytime the computer is turned off and turned back on, the wireless adaptor disappears from Control Panel>Network Adapters, we...
Network & Sharing
Retail Plus Mini Wireless USB Adapter
I recently purchased a Compaq Presario desktop with no integrated wifi. So I picked up a usb adapter. The Retail Plus website says the adapter is compatible with Windows 7. However, after I run the setup and plug in the adapter, the drivers do not install. My apartment is wireless only, so I can't...
Drivers
How to determine WPA2 adapter capability
I have an old Hawking PC Card network adapter (HWC 4G) lying around which I suspect is not capable of WPA2 security. Is there a way to find out for sure? Assuming the HWC 4G is not capable of WPA2, what would be an in-expensive G or N adapter to add to an old notebook that would be WPA2...
Network & Sharing
dwl g-122 wireless adapter Driver issue
i have d link dwl g-122 wireless adapter. I m using windows 7. windows 7 successfully install the driver but when i try to establish a wireless network it gives and error occurred "an unexpected error occurred". In device manager it shows that adapter is installed successfully. Thanks in advance...
Drivers
Belkin Wireless N+ Network Adapter Issue
I recently bought a N+ Belkin adapter, as my old adapter did not support Windows 7 and our household is upgrading to an N router soon. The USB adapter (model number F5D8055) works fine on a vista desktop that is connected to the router, and will seemingly install on my Windows 7 rig, but it...
Hardware & Devices
Wireless USB Adapter Issue - Aztech and Belkin
Hello there, I already successfully installed win 7 today. All my hardware working great except my wifi usb adapter. 1) Brand: Aztech Model: WL635USB *got driver support until windows vista only.
Network & Sharing
