Windows 7: base to the max only, 5.1 system problem
20 Mar 2013   #1
Fking
Microsoft Windows 7 Enterprise 64-bit
I've got a logitech 5.1 system which for some time now plays with base to the max no matter where the hardware controls of the base are.
I'm not even sure if it's a hardware or software problem, but it's really annoying, any idea how to at least narrow down the possible problem source?
20 Mar 2013   #2
bobkn
Windows 7 Pro X64 SP1
What's the interface from the PC to the audio system?
(The only sound device that you list if from the graphics card, which would usually be digital only: HDMI, maybe DisplayPort.)
Does your sound controller have bass settings?
28 Mar 2013   #3
Fking
there are 3 or 4 3.5mm jacks that go from the motherboard to the main body of the system which is also the subwoofer
i have some settings and sound effects for it under control panel> sound if i play with the equalizer there it seems to affect it.
Seems that it's just the hardware controll of the base that's connected to the subwoofer itself doesn't work anymore
28 Mar 2013   #4
bobkn
If I understand things correctly, you're using the Realtek onboard audio, with analog connections to your sound system.
The bass control of your sound system isn't working.
Sounds like a repair/replacement of the sound system is in order. Or, live with it.
This Base system driver problem.
Could someone give me a hand. I'm not sure what to do if anything. I have a lot of these with out and drivers. Also can't update drivers. I can remove them and they come back. I can disable them and it doesn't seem to hurt anything. I'm really not sure where they came from but maybe Asus AI...
Drivers
Base System Device
I have recently installed my Toshiba Satellite a665-s6904 with Windows 7 Professional x64. When I went to use it, I had several devices that couldn't be found and now my computer is incapable of doing anything. I even tried to plug in the Ethernet cable and I still can't get online. How do I fix...
Hardware & Devices
Base System Device
ACER / ASPIRE 5270G, recently changed from Vista Home to Windows 7 Ultimate N. In Device Manager...> Other Devices.... There are Two Base System Devices & One Unknown device are highlighted with yellow icon. Problem are 1. my laptop camera not detecting 2. Bluetooth not working 3. pre-built...
General Discussion
Base System Device Problem?
i got question mark on my system device in Devise Manager... what driver or software should i install? my laptop is dell inspiron 1420
Drivers
base system device
In device manager under 'other' there is a yellow Based System Device. I try to update it and it gives me a error "no driver found". I got to dell and download the Richo chipset. I try to insta1l and I get this this error, "You have to run the 64bit version DPInst.exe on this machine." So I put...
Drivers
base device system
hello i have hp pavilion dv4 series entertainment notebook came with vista , i formated it and install window 7 but i discover that my touch mouse on the notebook is not working properly also base system device is not found . please advice me on what to do
Drivers
