Windows 7: My front USB 3 port doesn't read USB 3 device, but reads USB 2 device
26 Mar 2013   #1
dino1989
I have ASUS P8Z77 V motherboard and the front USB 3.0 headers are not working when I plug in a USB 3.0 device. When I plugged in my Kingston USB 3.0 Flash Drive into the front USB 3.0 header it didn't work. As in, when I tried to move a file into the flash drive, the drive disappears and it makes that USB unplugged sound. But if I connect it to any back USB 3.0 ports, it works fine.
But, if I plug in my Scandisk USB 2.0 Flash drive into the front USB 3.0 ports, it works without any errors.
This only happens with USB 3.0 devices and it has to be connected to front USB 3.0 ports.
I have installed all the latest drivers and updated my BIOS to the latest one. I have checked if USB 3.0 is enabled in BIOS.
I asked to my friend to help me. He has AMD rig with ASUS M5a99X EVO motherboard, which has a front USB 3.0 header. We installed all AMD drivers for his rig updated everything, the front USB 3.0 ports worked fine. We manage to transfer all the files at full-speed on to the Kingston 3.0 flash drive without any errors, so I know its not my PC cases USB 3.0 cable at fault.
Any help. Please note the front USB 3.0 ports work if I plug in a USB 2.0 device.
27 Mar 2013   #2
Saurabh A
Windows 7 64bit
Hi dino1989,
I checked the motherboard manual and it talks about only 2 USB 3.0 ports; appears that it offers 2 USB 3.0 port connectors at the back panel:
Please take a glance at the motherboard layout. Connectors highlighted (11) are 10-1 pin USB56, USB78 & USB910. These connectors are used for USB 2.0 ports (9 ports) at the rear panel. If the 2 USB ports in front are also connected to there, they may comply with USB 2.0 specification and would support upto 480 Mbps connection speed. (Tried but could not find anything in the manual that gives a clue about the source of the USB ports in the front).
However, you may go to 'Onboard Devices Configuration' and try setting 'USB 3.0 Controller' as [Enabled] in 'BIOS' to see if that gets the USB 3.0 ports functional in the front panel. This 'Enables / Disables' the USB 3.0 controller.
To access 'motherboard BIOS', you may want to refer to this manual: http://dlcdnet.asus.com/pub/ASUS/mb/...5A78L-USB3.pdf
Hope this helps. Do reply with the findings.
27 Mar 2013   #3
dino1989
Thanks for the reply. But I no longer use M578L/USB3 Motherboard. Like I stated in my thread I have P8Z77 motherboard
27 Mar 2013   #4
carwiz
Windows 7 Pro-x64
Verify that you are using a USB3 extension to front panel and that it's plugged into the USB3 header.
What PC case are you using? Did it come with the front ports and interconnect cable?
27 Mar 2013   #5
dino1989
27 Mar 2013   #6
Saurabh A
Windows 7 64bit
Hi dino1989,
Thank you for the reply.
Was stumped by the 'system configuration' detail; apologies for the miss.
As correctly suggested by 'carwiz', pleas ensure a valid physical connection:
@carwiz: thank you for the valuable inputs.
If the issue persists, you may also check 'BIOS settings':
- Ensure that the 'Legacy USB Support' is 'Enabled' (It enables the support for USB devices on legacy Operating systems). Ensure that 'USB 3.0' support is 'Enabled'
- Also go to 'Onboard Devices Configuration' and try setting 'ASmedia USB 3.0 Controller' as [Enabled] in 'BIOS'
You may find the motherboard manual useful: http://dlcdnet.asus.com/pub/ASUS/mb/...P8Z77-V_LK.pdf
Hope this helps.
27 Mar 2013   #7
mjf
Windows 7x64 Home Premium SP1
Another possible explanation for problems is if the front header wiring provided by your case are long thin wires then you could have too much voltage drop (IxR). Some flash drives do consume more power than others (eg SanDisk). Can you try a mains powered USB3 HDD?
COM PORT missing in Device Manager
hello. Today I wanted to configure something in the COM PORT so I checked the device manager and I noticed that the COM PORT is not present. But it's always there before. Please help, how do I get it back? I'm using a laptop so I cannot open it...
Hardware & Devices
VIA HD Audio Deck - Front panel headphone device not producing sound
I built a custom desktop a couple of months ago. I have a Gigabyte Z77X-DH3 mobo inside an Antec Nine Hundred case. Gigabyte Z77X-DH3 Manual Nine Hundred Manual I'm not very sharp when it comes to computer audio, but here's what I'm looking at (I think...). The mobo has integrated audio...
device manager not seeing my 1394 port
Hi, I am using windows 7 and a while ago I added a combination firewire / usb2 pci card. I needed the firewire port for an older video camcorder that only uses firewire. I know that when I installed I tested to make sure I could capture using the firewire port. But since then I have had many...
Hardware & Devices
USB Device Not Recognized SPAM! on an unused USB port!
Ok this is driving me crazy. This all started when one day my G930 Logitech headset started becoming a pain in the ass to use. I had the charging dock plugged into one of the two USB ports behind my HP ZR30w monitor. Then after a few days I began to get a USB Device Not Recognized Error...
Drivers
HL-DT-ST DVD-RAM GSA-H55N ATA Device Wont read DVD's but reads CD.....
I had an issue with my DVDRW disappearing after i mistakenly uninstalled the drivers for it!!! thanks to stormy13 and others for sorting it out But now it wont read dvd's :( any idea why this is happennin???? I have updated the firmware too, this started just a few days back
Hardware & Devices
Device Port Conflict
I have a Port conflict between my HL-DT-ST DVDRAM GH22NS50 ATA Device and Windows Live Messenger (Build 14.0.8089.726). Running Windows 7 Home Premium. When I try running Windows Live Messenger it brings up a Windows error saying it can't find a disc in the drive and I can't stop the message...
General Discussion
