Windows 7: Hard Drive making a strange noise when running on battery,what is the
29 Mar 2013   #1
John16
Windows 7 Professional
I noticed my HDD has been making this strange noise when running on battery like its trying loading something for a quick second but once it is plugged in charging the noise is not there, What could the possible problem be. I'm not sure if any of this could cause such as updating the BIOS and fresh install of windows 7
29 Mar 2013   #2
ICIT2LOL
John obvious question mate how old is the battery cos it sounds like it has seen better days - it cannot deliver the current needed and the HDD sounds like itis struggling to spinn up and find data.
Search this Thread:
Advanced Search
External hard drives making clicking noise
So currently my computer cannot open (operating system not) and decided to check my external 1tb Toshiba, I just plugged it in and opened the computer, then it spun and lit up, and had clicking noises, then I decided to check again while writing this, and there were no clicking noises anymore,...
Hardware & Devices
Cmos battery changed but hard drive is producing strange noises...
Hello Friends... My PC was giving, system battery low, message so i replaced cmos battery but it didn't boot until i set bios to its default values so finally i was able to boot but my hard drive is making strange noises now so even if right click and press refresh in the dialogue box, my hard...
Hardware & Devices
CPU fan is making a strange noise
I've had this computer since March and I'm using the stock heat sink it came with. Recently I've noticed that sometimes programs will be unresponsive for 4-6 seconds and then it will go back to normal. The same thing can be said about the mouse, sometimes it doesn't even move. I took apart the side...
Hardware & Devices
Comp will not start (black screen NO POST) Cd drive making odd noise.
I'll give anyone who reads this as much info as possible. I have a desktop build that contains these parts: ASRock > N68-S UCC Rocketfish 200gb hdd (shows up as about 186 gb) 4 gb ddr ram (motherboard only supports ddr2) Amd Phenom II 3.1GHZ dual core cpu
General Discussion
Internal hard drive making beeping noise, laptop won't start up
Hi, I am using a Dell Inspiron 14 laptop. A few days ago, I noticed that my laptop has become incredibly slow (the system will hang sometimes, and continue as per normal after a while), and this coincided with my laptop beginning to make this weird, sharp beeping sound. At first I did not pay...
General Discussion
Hard disk making noise on particular location and unable to format it.
Hello friends, I have Hitachi SATA 60 GB hard drive and recently started making severe Noise from it. So, I have partitioned hard drive now like below and traced where exact position sound coming from. 24 MB <- for Boot sector 15 GB <- Making noise and formatting stops by 14% 14 GB...
Performance & Maintenance
