Windows 7: Problem with Toshiba Battery
30 Mar 2013   #1
Y5N
Windows 7 Édition Intégrale x64
Hi , i have this toshiba satellite C870-15R , and my problem started today when i tried to boot only with my battery but it didn't , and plugged it, and successfully booted , i checked bettery icon , it show 100% charged , is there anything you can help me with thanks in advance , ( ask me for any informations about the laptop )
i attached 2 pictures for battery notifications , first one with battery attached , second picture when i remove the battery ( just to show the battery isn't dead )
( i have windows 7 ultimate x64 )
Problem with Toshiba Battery-problem-2.png Problem with Toshiba Battery-problem-1.png
30 Mar 2013   #2
codekiddy
Windows 7 Enterprise x64 SP1 Version 6.1 Build 7601
If I understand french, the message shows that your battery is not detected (it may be dead/dilapidated).
Can you boot up you PC with battery AND AC adapter(as well) plugged in?
31 Mar 2013   #3
Y5N
about the pictures, the left is when i remove the battery, the right one is with battery on
and yes it can boot up with AC adapter and battery (that's what the right pic shows , with 100% charged )
and another thing that's battery LED is off even the battery is plugged in
Battery problem maybe....
I've done a clean install of Windows 7 Ultimate on my old laptop. It ran good for a few days but yesterday, I noticed that a red X appeared on the battery icon saying that I should replace my battery. I didn't care about the message because this message had appeared a few times a long time before...
General Discussion
Battery Problem - Consider replacing your battery
Last night when i switched on my laptop i was welcomed by a red cross on my battery icon which says consider your replacing battery :( I bought the laptop a year ago ,actually 13 months ago but i don't think it is the time to change my battery ! What can i do ?? Can i use my this battery for a...
Hardware & Devices
Battery Replacement Toshiba OEM or Battery-Biz
I have to replace the battery on a toshiba L355-S7915 laptop. Which battery is better? The Toshiba battery or the B-5040H from battery-biz. anyone use battery biz?
Hardware & Devices
What are the Proper settings for longer battery life in Toshiba NB500?
My brother just bought a Toshiba NB500, its a Notebook running in Windows 7 Starter. And he saw a website that says that the battery capacity can be more or less 8hrs. Then he wants to customize his settings to make it. He already put to the lowest possible level the brightness settings. but it...
Performance & Maintenance
Battery problem
Hey sinced I installed W7 32x on my Acer extensa 5630g my battery lasts like 10min... Worked perfectly fine on vista. When i hoover over the "battery icon" it says (Crappy translated, hope you get what i mena anyway:]) So, is there any special driver or something to download?
General Discussion
battery problem
i have the problem about my battery....the battery icon show the message "consider replace your battery".... but before today i have no problem with my battery.... please help me.... why is it happened and how to overcome this problem.... tq..... the X mark on battery icon is annoying....
Hardware & Devices
