Windows 7: Usb port for wired mouse stopped working, says exceeded power level
02 Apr 2013   #11
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
I agree with alphanumeric's conclusion. I would replace the mouse and quit trying to use it so you don't damage anything permanently.
02 Apr 2013   #12
herbc
win 7 64 Home edition
alright thanks guys, appreciate the help
02 Apr 2013   #13
Britton30
Microsoft MVP
You're welcome, please let us know the outcome with a new mouse.
USB 3.0 port stopped working
Hello, History: I have had a similar issue in the past with my last PC (which had serious issues and was replaced with this one that is only a few months old now) and got help from these forums, the problem was completely fixed but following the same steps does not work for me this time. ...
Hardware & Devices
USB Port Stopped Working after Power Surge
Hi After a power surge on hub port when attaching a card reader to a front USB port one of my external hard drives disappeared. The drive works fine and is now on another USB port. The non functioning rear USB port has the following properties (image 1) and the location address looks...
Hardware & Devices
4 Port USB Problem Stopped Working
Hi Everyone I have recently discovered that my 4 USB port splitter has stopped working suddenly. It is about 4 years old and I am pretty sure it only supports USB devices up to 2.0 http://www.gamesalor.com/dianzi1/d4/9393/1.jpg I am not exactly sure what caused it to stop working suddenly...
Hardware & Devices
My mouse Usb port stops working. but starts working again after a day.
Hello! I'm using my laptop in a desktop mode. but some days when i start up the computer the mouse is on (Sees the red optical light.) But the cursor dont move when i move the mouse. when i drag the cable out and in again the ligh wont turn on. i change usb port and it works. 1-3 days later the...
General Discussion
Wired Internet Stopped Working
Hey im new to this forum and i am frustrated with my internet :mad: Im currently using a Western Digital box, wired to the box and to my PC. It worked for a couple of days then suddenly it stopped working, yellow exclamation mark. Heres my Ipconfig.
Network & Sharing
BSOD after USB port stopped working.
Hi, I use windows 7 64 os laptop . Today while working all of a sudden all usb ports stopped working, I restarted the machine , but the pc couldn't shutdown properly. While shutting down I observed an BSOD. I have attached the dump file, also I'm using latest drivers. Can you please...
BSOD Help and Support
