Usb port for wired mouse stopped working, says exceeded power level
  1. Posts : 255
    win 7 64 Home edition
    I never had a problem before but one of my usb ports stopped working. I just get a message saying that i exceeded the power level. When i tried it on other ports that particular mouse doesn't work in any of them, however my other mouse which is wireless works.
    Any ideas
  2. Posts : 2,686
    Probably a short in the mouse circuit board or cable and is drawing excessive power from the USB port. May be time for a new mouse.
    Jim
  3. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    As a test try the same mouse in another PC. Unplug other USB devices too.
  4. Posts : 365
    Windows 7 x64 / Windows Server 2008 / Linux (Redhat & Deb distros) / OS X / More
    That problem happened to me 10 years ago. Cause was that cat chewed on the mouse cord. My solution was to buy a new mouse. Do you have cats?
  5. Posts : 255
    No cats guys, the mouse is actually a new LG scanner mouse that has worked perfect for two months up to this point.
  6. Posts : 24,479
    What about other USB devices, did you miss that post? Just because it's new doesn't mean it's not defective now.
    did you try on another PC as suggested?
  7. Posts : 255
    I have no other pc's to try it on, sorry.
  8. Posts : 24,479
    How about trying another mouse?
  9. Posts : 255
    Yes my wireless mouse works , oddly when i plug the wired non working mouse into the usb port that's next to the working mouse it renders both mice dead.
  10. Posts : 4,466
    Windows 10 Education 64 bit
    USB ports are often grouped in pairs and may be driven by the same IC. You kill one and the other dies with it. It does sound like the mouse has a short circuit in it. Even new stuff can fail prematurely. USB ports have a built in overcurrent protection so if a device draws more than 500 MA the port will shut down. You normally have to shut the PC down and power cycle it for the port to reset itself. Its happened to me and I had to unplug the AC power cord and hit the case power button to drain the power supply before it would reset.
