Windows 7: Usb port for wired mouse stopped working, says exceeded power level
01 Apr 2013   #1
herbc
win 7 64 Home edition
I never had a problem before but one of my usb ports stopped working. I just get a message saying that i exceeded the power level. When i tried it on other ports that particular mouse doesn't work in any of them, however my other mouse which is wireless works.
Any ideas
01 Apr 2013   #2
Phone Man
Probably a short in the mouse circuit board or cable and is drawing excessive power from the USB port. May be time for a new mouse.
Jim
01 Apr 2013   #3
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
As a test try the same mouse in another PC. Unplug other USB devices too.
01 Apr 2013   #4
FaberTech
Windows 7 x64 / Windows Server 2008 / Linux (Redhat & Deb distros) / OS X / More
That problem happened to me 10 years ago. Cause was that cat chewed on the mouse cord. My solution was to buy a new mouse. Do you have cats?
02 Apr 2013   #5
herbc
No cats guys, the mouse is actually a new LG scanner mouse that has worked perfect for two months up to this point.
02 Apr 2013   #6
Britton30
Microsoft MVP
What about other USB devices, did you miss that post? Just because it's new doesn't mean it's not defective now.
did you try on another PC as suggested?
02 Apr 2013   #7
herbc
I have no other pc's to try it on, sorry.
02 Apr 2013   #8
Britton30
Microsoft MVP
How about trying another mouse?
02 Apr 2013   #9
herbc
Yes my wireless mouse works , oddly when i plug the wired non working mouse into the usb port that's next to the working mouse it renders both mice dead.
02 Apr 2013   #10
alphanumeric
Windows 10 Education 64 bit
USB ports are often grouped in pairs and may be driven by the same IC. You kill one and the other dies with it. It does sound like the mouse has a short circuit in it. Even new stuff can fail prematurely. USB ports have a built in overcurrent protection so if a device draws more than 500 MA the port will shut down. You normally have to shut the PC down and power cycle it for the port to reset itself. Its happened to me and I had to unplug the AC power cord and hit the case power button to drain the power supply before it would reset.
USB 3.0 port stopped working
Hello, History: I have had a similar issue in the past with my last PC (which had serious issues and was replaced with this one that is only a few months old now) and got help from these forums, the problem was completely fixed but following the same steps does not work for me this time. ...
Hardware & Devices
USB Port Stopped Working after Power Surge
Hi After a power surge on hub port when attaching a card reader to a front USB port one of my external hard drives disappeared. The drive works fine and is now on another USB port. The non functioning rear USB port has the following properties (image 1) and the location address looks...
Hardware & Devices
4 Port USB Problem Stopped Working
Hi Everyone I have recently discovered that my 4 USB port splitter has stopped working suddenly. It is about 4 years old and I am pretty sure it only supports USB devices up to 2.0 http://www.gamesalor.com/dianzi1/d4/9393/1.jpg I am not exactly sure what caused it to stop working suddenly...
Hardware & Devices
My mouse Usb port stops working. but starts working again after a day.
Hello! I'm using my laptop in a desktop mode. but some days when i start up the computer the mouse is on (Sees the red optical light.) But the cursor dont move when i move the mouse. when i drag the cable out and in again the ligh wont turn on. i change usb port and it works. 1-3 days later the...
General Discussion
Wired Internet Stopped Working
Hey im new to this forum and i am frustrated with my internet :mad: Im currently using a Western Digital box, wired to the box and to my PC. It worked for a couple of days then suddenly it stopped working, yellow exclamation mark. Heres my Ipconfig.
Network & Sharing
BSOD after USB port stopped working.
Hi, I use windows 7 64 os laptop . Today while working all of a sudden all usb ports stopped working, I restarted the machine , but the pc couldn't shutdown properly. While shutting down I observed an BSOD. I have attached the dump file, also I'm using latest drivers. Can you please...
BSOD Help and Support
