Windows 7: Intermittent HP dv7 power problem
23 Apr 2013   #1
R Fernandez
HP laptop dv7 almost two years old. Still under hardware waranty. In the past two months I had this problem. I don't happen all the time. Three times to be exact. Laptop will not turn on when I press the power button after shut down. Battery is fully charged. The only way I can turn laptop on is to remove the battery and plug it back in. The laptop will than turn on with the power button. The light around the touch comes on.
Any advice or should I take it in for repairs?
23 Apr 2013   #2
benjy206
Windows 7 Ultimate 64-bit
Hi R Fernandez.
Since it is still under waranty I would take it to them before you go messing with it. It could save you a lot of hassle
intermittent failure of screen saver and power settings.
intermittent failure of screen saver and power off to activate? Hi. My Win 7 Desktop computer, unlike my laptop and other Win 7 computers, has a power and screen saver setup that, at times, never activates? I have checked background processes and can't understand why at times it kicks in and...
Performance & Maintenance
USB Intermittent Drop Out - Not Power Related
Hi all, I found this forum looking for an answer to my USBs randomly cutting out, so I apologise my first post is a cry for help. I have a Samsung np530u3c-a01uk series 5 laptop running windows 7 64 bit. The problem I'm having is with the USB ports. I have 2 USB 2.0 ports and one USB 3.0...
Hardware & Devices
Intermittent Driver Power State Failure event id 41 in Firefox
I have had this 4 time, three within the last week. Dell diagnostics have run with no errors in hardware, ram, or hard drive. No excessive or unusual temperatures noted in I8kfangui. Running updated W7pro Is there anything obvious from my attached zip file? Please let me know what else I...
BSOD Help and Support
Intermittent power off
Over the past 2 years my PC has been afflicted with random power off/power on/reboot events. It will go for months without these and then have multiples of the events in a day. (I had 8 of them 3 days ago.) I assume I have a hardware problem, but nothing has been found and I'm grasping at...
BSOD causing intermittent power to monitor on boot
Hi, Firstly, thanks for all the experts here, i have found some very valuable information! OS: Windows 7 Home Premium x64 i7-2600K CPU @ 3.40 Ghz OEM 8Gb RAM Asus P8P67Pro Harware & software build around 6 months old
Intermittent XP-Seven sharing problem
Am using an XP machine as a central point for sharing files (not running a Server OS) and have set up multiple drives/folders for read-only sharing. Works fine with the other Windows machines (mix of Xp, Vista, and Seven). But, if the XP box is not used for a while, it will go into power saving...
Network & Sharing
