Windows 7: Hard Drive seems always busy, busy, busy
08 May 2013   #1
kuliddar
Windows 7 Home Premium x86
Hey guys,
I posted this also on Tomshardware.com as I'm trying to find a definite solution to my HDD issue. Hoping to find some potential solutions here as well.
I've been noticing lately that my hard drive seem to always be busy processing. It doesn't matter what I do...it's as if something is working in the background. Now the only change was last month when my video card died and I replaced it with a new one (Radeon HD7750) but I don't see how it would related...or does it?
In any case, my computer isn't new. It's a Dell Dimension 9200. The current hard drive is the original: A 500gb Samsung HD501LG. I ran a whole bunch of different programs to check the disc such as HDTune and Active Smart and so on. All say drive is ok so I'm confused. The only message I received was from the Performance Monitor saying, "The average disk queue length is 2. The disk may be at its maximum transfer capacity due to throughput and disk seeks".
I had done a clean install about 4 months ago and not even half of what is currently on my HDD is back on as back then I realized I had too many games installed and didn't play them. Hence there is even less data on . Indexing is off, defrag is off. One thing I can point out is that some of the PC games I will play will make my HDD go berzerk (they didn't before) and some will literally freeze up and crash...some other will freeze for a good 10-15 seconds and then unfreeze.
This is for any application...even internet browsing through IE, FF and Chrome.
Any thoughts on the possible problem?
Specs:
Dell Dimension 9200
E6600 DuoCore 2.4ghz
Windows 7 (32bits)
500gb HDD
4gb ddr2 ram
Gigabyte Radeon 7750 - 1GB GDDR5 (Factory Overlocked 880mhz)
08 May 2013   #2
UsernameIssues
W7 Pro SP1 64bit
What, if anything, does the tab named Disk show within Resource Monitor show.
Or you can try Process Explorer.
08 May 2013   #3
bulletng
Windows 7 Pro x64
Is this your primary hard drive? Does it have all your stuff installed on it (OS, applications, etc)? Do you see any processes or strange services that could be using all the resources up? Maybe Windows is trying to Index the hard drive contents.
08 May 2013   #4
kuliddar
I only have one drive that has everything on it...always had.
I did a diagnostic on my CPU just to make sure but that passed. The resource monitor shows the Disk graph going top to bottom, even filling the whole box green.
09 May 2013   #5
UsernameIssues
W7 Pro SP1 64bit
Look to the left of the graphs and see if you can tell which app is causing most of the activity.
09 May 2013   #6
bulletng
Windows 7 Pro x64
Yeah it sounds like you just have an application that's not working properly.
09 May 2013   #7
kuliddar
I will look at this tonight. I also found an old card (GF 8400) to see if it's video card related...which I doubt but I'll try anything at this point.
09 May 2013   #8
kuliddar
Haven't tried the card yet but looking at process' it seems all over the place. Then most of these disappeared an d new ones took their place....just as many....it's as if all my programs are working at the same time???
I attached a pdf to show you guys.
09 May 2013   #9
kuliddar
Confirming the card has nothing to with this. The GF8400 made no difference at all. A few minutes I got a memory dump blue screen as well...a first since I got this computer. Starting to think the HDD could slowly dying...
10 May 2013   #10
UsernameIssues
W7 Pro SP1 64bit
Consider making a thread in this subforum:
BSOD Help and Support - Windows 7 Help Forums
Be sure to follow these posting instruction
Blue Screen of Death (BSOD) Posting Instructions
Their analysis of your last bsod files might help find the root cause of this issue.
Server Busy
From time to time when I click to perform an action I receive a notice in a window named "Server Busy". When I click on "Switch to" it goes to the start window, so I do not know which program to activate and correct the problem what ever it is. This is the message: This action cannot be...
General Discussion
I'll be busy...
As per title, you won't see me much on the SevenForums till mid-December. I'll be busy training and working too. But gonna watch out for hotfixes if present! Wish you good, guys! ;)
Chillout Room
Window is busy?
Recently I have been getting the odd message below. Sometimes it happens if I click a link on a page and other times it pops up with only one tab open without clicking anything. If I close a tab with the "X" it doesn't happen. Due to the language of it, "..might cause some problems." I'm...
Browsers & Mail
Window busy
Hi all, If there is a thread similar to this, sorry,but I did a search and didn't find anything. All of a sudden,I can't get any sites to open,and when I close out IE11 I get the Window Is Busy screen. I had IE10 and thought maybe it had a problem,so I installed IE11. No change. Homepage site...
Browsers & Mail
Secondary Hard Drive being lost when primary is busy.
Folks, I have a strange problem which has gradually been getting worse over the past couple of months. I have a system which I built with a primary SSD containing the OS and a secondary 1Tb WD caviar green drive which contains mostly media files. The second drive is partitioned into 650mb,...
Hardware & Devices
Server Busy
Yesterday I saw this http://www.mediafire.com/imgbnc.php/dfbfbade4245c897235c4474037bd6fc842e928ce8bfeb37b1da27a7d5c07c452g.jpg What might be the cause.
Software
