Windows 7: USB problems...system freezes until drive is dis-connected
19 May 2013   #1
tonewheelkev
Hi Folks
...really fed up with this one, and haven't got a clue what to do
Attempts to transfer files to/from micro Sd card (in USB card reader) result in transfer 'hanging' until USB connection is broken.
Occasionally...it appears that there is some progress....but painfully slow.
A Geen 'Progress' bar appears in the address bar all of a sudden....I hadn't noticed this before.
19 May 2013   #2
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
Media may have gone bad? I wouldn't trust it and get another one, it happens.
You are probably hitting a bad sector when it hangs, so I'd try to copy smaller amounts off of it.
If this is used in say a camera, then I would definitely toss/replace it once you got all you could.
E: drive formating problems, system prevents full space wanted
hey guys so recently i cant use my other drives E: with out it crashing as I log on (2 bootable drives) C: Windows 7 Home premium, 64bit E: Windows 7 Home premium, 32bit so ive decided to format the HDD since Its useless to use, but unfortunetly it says "Windows cannot format the system...
Hardware & Devices
network system tray icon shows not connected but I am connected
So, this is not a major issue but kind of annoying. Recently I have noticed that the system tray icon for the wireless network always has that little red X and if I open the Network and Sharing Center it says "You are not currently connected to any networks." When I click "See Full Map" it shows...
Network & Sharing
Secondary Hard Drive freezes system before Windows launch
My system runs Windows 7, 64bit OS. Replaced Socket 775 Mother board and CPU with Socket 1155. ASUS was manufacturer of both old and new mobos. Kept all hard drives and reinstalled them. 2 x Seagate 350Gb Sata 3.0 (one is the boot drive with OS) 1 x Western Digital Caviar Green 1.0...
Hardware & Devices
hp laptop audio and video problems (unless connected through hdmi)
Problem started a little over a month ago on my HP laptop running Windows 7 64bit. When I connect the laptop to my either of my TVs through an hdmi cord everything works fine. Videos run smoothly and the audio is in sync as if there's no problem. If I try to watch a video on just the laptop...
Having problems with system freezes.
I have just re-built my system with some new parts (almost finished) and the computer freezes after a short while. No blue screens or errors, just stops. If there is music playing it distorts for a little while (random noise really) and stops. Specs: * AMD Phenom II X6 3.3 GHS * Corsair XMS3...
BSOD Help and Support
DNS problems after connected to public network
Hi! I've got the following problem on my Lenovo ThinkPad SL510 running Windows 7 Enterprise x64: When running my PC in my home network everything works fine. I can ping IPs on my network and i can ping their hostnames. However, when I have been logged in into the wifi network at my school...
Network & Sharing
