Windows 7: Power led won't turn on
22 May 2013   #1
RonAshman
This is a non-urgent question. It's just a power led not lighting up.
It's a friend's PC. He told me it used to power up when the PC was new, but after he took it to a service tech it didn't turn on when it came back, neither did the HD led.
Well the HD led did turn on, it was just that it was not placed where it should be (it was inside the case).
So, getting to the point, I installed a new mobo. An Asrock N68-VS3 FX.
I installed the power led pins to where the manual says. There are two cables with one pin each coming from the case, one is power led (+) and the other one power led (-). I followed the manual's instructions and it doesn't light up. I changed them just in case, didn't work. I also tried connecting them in a different way (in the correct pin place).
So could this just mean the light led is dead? It doesn't seem disconnected to me (http://img194.imageshack.us/img194/9316/sam0009y.jpg)
Thanks for your help.
22 May 2013   #2
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by RonAshman View Post
Hi RonAshman,
I believe it might the be the LED at fault only. If the LED in the next to the power button you should try replacing the power button assembly itself to get this issue fixed.
Hope it helps.
22 May 2013   #3
RonAshman
I was afraid of that.
It's quite complcated to get there. It's not a common led light, it's a big one that lights up some words in the front of the case.
Anyway... I'll see if I dare. If not, I just installed this new system for free for a friend, so that should be enough :P
I just wanted to know if I was maybe missing something in the connection.
Thanks a lot!
22 May 2013   #4
Dwarf
Windows 8.1 Pro RTM x64
Try temporarily swapping the HDD and Power LEDs over. That should indicate whether you have an LED fault, or if there is no power to it.
23 May 2013   #5
SandeepP
Winndows 7 32 bit
Thanks a lot!
Hi RonAshman,
I understand it would be a hassle to change the LED. As, you have exhausted all the options this was the only one left.
Turn off usb power
Hi *, I am looking for a way to turn off/on the 5V power supply for an USB device. The purpose is to reset a uC (not my uC) which is powered via USB. Is there an API tho achieve this? I found the option "usb selective suspend " for power saving and I thought there is a way to do this. ...
Drivers
I can't turn on laptop! Power button problem
Sorry for reposting thread. I hope this doesn't ruin my reputation as a person. My other thread was named incorrectly, therefore not getting as much notice. Sorry about that. :huh: Anways.... Okay, this is I did something really dumb. Yesterday I was changing the thermal paste in my laptop for...
General Discussion
Computer won't turn on after Power Outage
I was sitting at home enjoying myself one day and then I suddenly hear a thunderstorm outside. First the monitor flashes and seconds later everything in my room turns off and back on immediately, everything except my computer. The monitor and everything was working perfectly but the computer itself...
General Discussion
Computer will not shut down/turn off power
Hi guys. I'm having an issue where the computer will not shut down unless I turn it off at the PSU/power supply (I've had the issue for about a month now). Windows 7 will run through its normal shut down procedures, then the screen goes black, but nothing happens apart from the fans going...
General Discussion
Is It possible to turn the computers power on wirelessly
I don't know whether this would matter If I'm asking this question In a windows 7 forum \ Linux forum whatever but I am running 7. Say If I open up my desktop computer and do something\add something to the wireing of the power button , would I then be able to turn my computer with A wireless...
Hardware & Devices
Power Outage.. now computer won't turn on
Okay, so. I know everyone has heard this scenario, and I have done a good amount of time on google searching for an answer, and have yet to come across something that helped. What happened: Overnight on Tuesday we had a pretty wicked thunderstorm which knocked our power out when I was...
General Discussion
