Windows 7: Power supply parts for Gaming
27 May 2013   #1
ronell123
Windows 7 Home Basic 32 bit
Hi guys. Can you suggest about what a power supply could be more than enough for a PC? For hardcore gaming. lol thanks
27 May 2013   #2
smarteyeball
Corsair AX850W
A few more details, such as your definition of hardcore gaming. Opinions vary wildly.
Essentially the rule is Single GPU, 750W. 2 GPU's 850W 3 1000W+
Never cheap out on a PSU for 'hardcore use'. Always go with a reputable brand.
28 May 2013   #3
madcratebuilder
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
The GPU(s) can eat the watts. Two or even three power hungry gpu's, pair of optical drives plus hhd's-ssd's. Overclocked CPU with H2O pump. Add few USB devices and you can see why a 850 or 1000 watt may be the minimum size. 1250 watt PSU's are around.
28 May 2013   #4
ronell123
Thanks for the replies. Do you think this will be enough? Omni Electrical the AVR-1000
28 May 2013   #5
sygnus21
Windows 10 Pro
First, in order to really suggest a power supply to you, we really should know what your system specs are. Otherwise we're just guessing and speculating.
That said, I'm willing to bet you don't need anything bigger than an 850. And unless you're running multiple high powered GPU's, you definitely don't need a 1200 watt PS.
And there's obviously some miscommunication here because...
Quote   Quote: Originally Posted by ronell123 View Post
Omni Electrical the AVR-1000? What kind of Power Supply are you talking about?
28 May 2013   #6
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
The link you provided does not look to be a computer supply. At least not one that I've ever seen. I always recommend Corsair, Seasonic or Antec power supplies. Those are good quality power supplies that will put out the power they claim, where others may not. They also have safety features built in.
28 May 2013   #7
kbrady1979
It's rare that a person needs 1000 watts or more. Share, or fill out your system specs as fully as possible and we can narrow things down quite a bit.
28 May 2013   #8
Stephanie
Win 7 Pro x64, Win 10 Pro x64, Linux Light x86
AVR-1000 looks like some form of UPS ?
28 May 2013   #9
kbrady1979
Automatic Voltage Regulator
29 May 2013   #10
ronell123
here are the specs. I'm planning to improve my system this june. Maybe you can give me some good suggestions?
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
Which power supply is better for gaming?
Which power supply is better for gaming? CHIEFTEC 750W PSU, 85+,230V W/CABLE MNG ( CTG-750C ) Or OCZ ZT Series 750W fully Modular 80 Plus Bronze, ATX12V v2.2 Active PFC ( OCZ-ZT750W-EU ) In future i might Sli/crossfire.
Hardware & Devices
Hardware Power Consumption-Picking a new Power Supply
Ok, so it's time again for me to pick a new power supply, however, I'm in need of some help determining the appropriate wattage for my hardware setup. AMD Phenom II X4 955 45nm AM3 GSkill Ripjaw X 16.0 GB Dual-Channel DDR3 @ 668MHz (9-9-9-24) Corsair TX750w (I dont think its the V2) ASUS...
Hardware & Devices
power supply
is this a good power supply? antec hcp 750 watt high current gamer or should i go for a ocz or corsair i need a 700 to 800 watt psu
Hardware & Devices
Power Supply
Hello, I am interested in the Nvidia Geforce N470GTX Twin Frozr II. My current card is an Geforce 9600gt. I believe my system currently got a 400W power supply. Do I need to upgrade it? And if so do I need to check anything as in compatibility with my motherboard? Thank you.
Hardware & Devices
Power Supply
Hi, i have the HuntKey H301 case with its original power supply, when im playing a game it is starting to do a weird noises, can i do something with this?
