Windows 7: How do I know if my device is running on USB 3.0 speed?
06 Jun 2013   #1
GTMoraes
Windows 7 Ultimate x64 Custom / Windows2Go / Ubuntu
Hi.
I've bought a ThermalTake Muse 5G, and on the next day, I overstressed the connector and it broke.
I've re-soldered it back (a lot of work and hassle, hope I don't go through this again) -- making sure the fixture is reinforced -- and now, although the device is detected, I don't know if it's making use of those extra connectors.
Right now, I'm moving 143.886 items (156GB) from the external hard drive (the Muse 5G with a Toshiba mk5059GSXP, 500GB, 5400RPM, SATA II, 8MB Cache; USB 3.0 Connected). The estimated time left is around 5 hours and the speed is ranging from 26MB/s to 36MB/s.
At the moment I'm writing this, it started to transfer one big single file, and the speed went up to 42MB/s
I used to get around 25MB/s on USB 2.0, and this speed could be enough to ensure that the device is working on USB 3.0 mode, but I'm still not sure. Is there something that I could run or see to make sure of that?
USB 3.0 Drivers are properly installed and I'm running on Windows 7 x64 Ultimate.
Time left decreased to 1 hour left, and it is stable at 43MB/s
06 Jun 2013   #2
Pauly
Win7 Ultimate X64
Sounds about right to me, my usb 3 drives and flash mem usually transfer single files around 35-45
06 Jun 2013   #3
GTMoraes
It just finished. Wow, this thing is too damn fast.
06 Jun 2013   #4
LMiller7
Windows 7 Pro 64 bit
The speed of a USB 3 interface is 5 Gb/s but no conventional drive can come any where near that. In practice your performance will be limited by that of the hard drive. The speed you were getting seems about normal. The estimated copy time is only that, an estimate. Actual times can be very different.
07 Jun 2013   #5
Mark Phelps
That's been my experience too. I've been using USB 3.0 for a while with an external SATA drive, and while I can achieve peak speeds of 100+, the average is around 50. That got better when I went to Sony a while back and downloaded the firmware and driver updates for my Renesas 3.0 chip. If you have the same chip, you should check the Sony site.
07 Jun 2013   #6
GTMoraes
I've heard about upgrading firmware, but I'm a bit scared to do so. Still got to know which chip is mine, also.
It's a PCI-E x1 expansion card, and the familiar generic chinese product box which doesn't give any information about anything.
Oh, you meant the device firmware? I upgraded it, even put a custom name for it haha
Enabled some new features, but speed is the same. It's an Asmedia ASM1051
is my ram running at the right speed?
ok, the specs on my motherboard from MSI say this here: MSI Global ? Mainboard - 790FX-GD70 ill attach an image. the board says DDR3 800/1066/1333/1600*/1800*/2133* (OC) DRAM, 16GB Max. i'm using the program Speccy and it says my ram is PC3-12800j so it should be running at 1600mhz... but...
Hardware & Devices
got new Ram... not sure if its running at full speed...
ok i got new ram today Vengeance® — 16GB Dual Channel DDR3 Memory Kit (CMZ16GX3M4A1600C9B) Memory Type: ...
General Discussion
How to know if CPU is running at full speed ?
Hey guys, I'm a 3D artist, and I'm currently rendering out a whole load of frames. I'm using a reasonable, Sony Vaio laptop for the task, which has an Intel i7-720QM, however I'd like to know what CPU speed it's currently operating at. I know that it says it runs at 1.6Ghz as standard but then...
Hardware & Devices
USB 2.0 running at (?)1.1 speed
Hi. When I connect my external hdd, it tells me that this device could work faster if I connect it to a Hi-Speed USB port. When I try to copy any files, transfer starts at about 70mb/s and stops after a few seconds, time left is «calculating» and when it starts again the speed is about 1.5mb/s....
Hardware & Devices
HIGH speed USB hub running at FULL speed.H
after dealing with PCI usb hub. i went and got external usb hubs and yes it worked on windows 7, but only FULL speed, my cam went from fast to laggie, iphone connect to usb hub had a message " it can perform faster if connect to a high speed port" , i check under device manager and it says " the...
Hardware & Devices
processor running at 1/3 speed WTF
First image is in windows 7 second in windows vista (separate partition) i mean WTF happened it used to run at full speed!! (its a 1.9 Dual core) http://i44.tinypic.com/mruwkp.png http://i39.tinypic.com/30a5qxj.jpg Windows 7 original beta (7000), should i bear through the paint and upgrade...
Hardware & Devices
