Windows 7: Multiple audio playing devices, playing the same sound at once
09 Jun 2013   #1
lolilodlol
Windows 7 Home Premium 32bit
Hi
I've been stuggling with this for a few hours now and am at the end of my wits..
I've got two audio devices that I would like to link to my PC at once.
I've got one plug connected to the back panel, and one to the front. But one always cuts off the other. In my sound devices, the system registers them both as: "speakers, VIA High Definition Audio, Standard device"
Is there any way that I can connect them both at once, and still have both of them outputting audio?
I hope the internet will save the day!
Many thanks in advance!
09 Jun 2013   #2
estXcrew
Windows 7 Home Premium SP1, 64 bit
If you use realtek,
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Otherwise You're pretty much screwed, only other way is to use Virtual audio cable, but you'd have to set it up every time you booted (and it costs 20$)
09 Jun 2013   #3
fireberd
I don't know about the rear mic and line in jacks, but you may be able to connect one to the Line In and another to the Mic in and be able to hear or record both. You would need to have the Stereo Mix (may be called System Mixer) as the default recording device in order to hear both inputs.
You could use a "Y" cable and connect both to the same port. And, you could even go further, if they are not stereo (2 channel) signals. The Line In is a stereo input, with a splitter type cable you could connect one input to one channel and the other input to the other channel.
10 Jun 2013   #4
lolilodlol
Thanks for the replies guys!
I ended up with putting one of the jacks into a 'side speaker' enrty and configuring my PC to four channels in the 'VIA HD Audio Deck'. I then checked the 'Speaker Fill' option and it worked!
Thanks alot!
No sound from speakers but audio playing
Hi; I dual booted win7 along with win xp . My sound card , Zonar Dg works fine in xp . i loaded the drivers for win7 . The sound bar in the speaker in task bar shows audio is playing and also shows playing in Zonar program . No sound is coming from speakers . Note : Sound did come from...
Playing sound through two audio devices simultaneously
Hello all. I have Bluetooth speaker that I have hooked up to my computer and is working properly. I would like to also use the laptop speakers simultaneously to create a kind of surround sound system. Is this possible? I have found many threads saying that it isn't. When I use the audio...
Audio sound intrrupting while playing mp3 with headphones
Iím facing this problem while playing the audio files(like mp3, wav...etc) with front panel headphones, the sound interrupting continuously (like 10 seconds sound-1 second mute-12 second sound-1 s mute-5 s sound-1 s mute) but there is no problem while playing video files. I opened the mixer from...
IDT High Def Audio, buzzing sound when playing any sort of audio.
Hello, Starting about a week ago whenever any audio is being played through my computer (speaker or headphone) I will hear a buzzing sound and occasionally the audio with skip. This happens weather I am playing audio that is being streamed from the internet or that is on my computer directly....
I need an audio player capable of playing multiple audio files simul
In Mac OS Quick time does this (I can have 10 audios all playing simultaneously). WMP nor VLC seem capable of this. I need a solution to this for both Linux/ubuntu and Windows 7. Maybe there's a way to customize vlc or wmp? Thanks.
crackling sound while playing audio
I installed win7 64-bit in my pc 2 weeks ago and found a crackling sound while playing audio.I checked that all drivers are up to date and working properly.I later installed xp in D drive and found audio working fine.I dont want to uninstall win 7.Please somebody help. thanks in advice.........
