Notebook display brightness low when plugging out power cable?
  1. Posts : 244
    win7pro 64bit
    As long as the power cable is plugged in in my notebook the brightness of my display is fine.
    But when I plug it out and use the battery the brightness becomes suddenly darker.
    Why?
    How can I prevent this switch-to-dark-screen?
    I found no corresponding option in the power plans
    Peter
  2. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
    Try going to the Power options and then click Change plan settings for your power plan then in the next window under battery at the bottom is a adjustment for brightness. Be sure to save changes one done.
    Jerry
    Notebook display brightness low when plugging out power cable?-power-options.png
    Notebook display brightness low when plugging out power cable?-edit-plan-settings.png
  3. Posts : 1,711
    Win 7 Pro 64-bit 7601
    Most laptops remember display brightness with power plugged and brightness when on battery, and switch setting depending on conditions.
    So, when display is darker just raise the brightness, and it should remember that in the future.
  4. Posts : 18,415
    windows 7 home 64bit
    Hi there .... Most Laptops have function keys to adjust the brightness Press Fn + ... Hope that helps
