Windows 7: Notebook display brightness low when plugging out power cable?
11 Jun 2013   #1
pstein
win7pro 64bit
As long as the power cable is plugged in in my notebook the brightness of my display is fine.
But when I plug it out and use the battery the brightness becomes suddenly darker.
Why?
How can I prevent this switch-to-dark-screen?
I found no corresponding option in the power plans
Peter
11 Jun 2013   #2
Bongo
Win 7 Pro x64 / Win 10 Pro
Try going to the Power options and then click Change plan settings for your power plan then in the next window under battery at the bottom is a adjustment for brightness. Be sure to save changes one done.
Jerry
Notebook display brightness low when plugging out power cable?-power-options.png
Notebook display brightness low when plugging out power cable?-edit-plan-settings.png
11 Jun 2013   #3
bobafetthotmail
Win 7 Pro 64-bit 7601
Most laptops remember display brightness with power plugged and brightness when on battery, and switch setting depending on conditions.
So, when display is darker just raise the brightness, and it should remember that in the future.
11 Jun 2013   #4
maxie
windows 7 home 64bit
Hi there .... Most Laptops have function keys to adjust the brightness Press Fn + ... Hope that helps
Any way to auto switch power plans when plugging in to charger?
anyone know how to do this? when plugging in to AC adapter, the system switches to a different power plan?
Performance & Maintenance
Plugging in USB device causes display to go blank
Whenever I plug in any USB device, the monitor will go blank, but the case fans and lights will continue operating. The computer remains like this until I hold down the power button to turn it off and then restart it. It will restart fine. In addition to the monitor going blank, all power is turned...
BSOD Help and Support
System Reboots When Plugging In A USB Cable
The title is somewhat misleading. This event happens maybe once every 20 plug-in attemps and only when I'm slightly up or down from a straight push in. The device doesn't matter. The port in question is one of four on the front panel of the case. The rebooting only happens with one port. ...
General Discussion
Plugging in notebook computer causes stuttering
Hi I have this weird issue where my notebook starts to stutter after coming out of hibernate whenever the power is plugged in. The mouse doesn't move, the audio goes out, videos stop, and sometimes I get a black screen that disappears in ten seconds. Sometimes after the black screen I get a...
General Discussion
Need help, display brightness
Hi im new to these forums:D and need some advice with my display brightness, i have an acer aspire 5935g and upgraded to windows 7, i upgraded to all new windows 7 drivers but the only downside was the display was sooooo bright:cool:, i have put the brightness low so it dont burn my eyes for now,...
Graphic Cards
Sound Notification when plugging power
Is it possible to get a sound notification every time i plug and unplug my power cord into my laptop ? There is no notification lights around the power jack in Sony Vaio . So after i plug in power i have to see the notification area to check whether the laptop is plugged in properly . Is there a...
