External Hard Drive problem
  1. Posts : 4
    Windows 7 ultimate 32bit96.1, Build 7600)
    When I connect my 1TB Buffalo MiniStation to my PC, -it does not show up on 'My computer'. The 'safely remove device' option is there. The device is also visible in Disk Management. I googled around for some time and the most common solution offered by others was to assign a drive letter to the drive. I tried doing that and got an error(see attached image). I have refreshed and restarted it several times. Same result.
    This has been happening since I formatted my internal C: drive. And no, the external hard drive does not require additional firmware. It works properly on my other 2 laptops(windows 7 & 8).
    Help will be greatly appreciated.
    Attached Thumbnails Attached Thumbnails External Hard Drive problem-untitled.png
  2. Posts : 1,269
    Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
    Have you tried a 3rd party partition manager tool? and made the drive ACTIVE?
    Here's a free good one, as backup to the Win7 one: [It's what I use]
    Active@ Partition Manager Free Download - Create Partition
    Just today gave me in use message on an external drive, I rebooted as some other program was trying to make use of it, probably my auto-defrag tool, then I was able to change the letter.
    Try that and if it still won't, try it in safe mode.
  3. Posts : 4
    Thank you for your quick reply
    I have AOMEI Partition assistant 5.2 which fulfils all my need regarding hard disks. I tried making the drive active but the option was greyed out. Tried it in safe mode, same results.
    Anything else I could try?
  4. Posts : 4
    UPDATE
    I tried to partition the unused 92 gb on the drive and it partitioned successfully and got assigned the drive letter 'I'. I can use it normally but the previous data is still not accessible and i'm getting the same error when i try to assign a drive letter. Someone help me.l
  5. Posts : 4
    UPDATE
    I went to device manager and uninstalled the usb drivers. When I inserted the hard drive, the drivers were automatically installed and the hard drive is working fine now. Some flaw with windows 7. Thanks for nothing forum users.
